Question about Canon MultiPASS F50 All-In-One InkJet Printer
How to hook up Canon multipass F50 fax
Don't I have to hook up Canon F50 to phone line first in order for it to work? How do I go about this.
    Problem Solver:
  • 7 Answers
Go to Canon web site for instruction manual: www.usa.canon.com/consumer/controller?act=SupportIndexAct
Posted on Feb 22, 2009
I need the drivers for a canon multipass f50 please
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and
select your model printer todownload :- http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Mar 14, 2011 | Canon MultiPASS F50 All-In-One InkJet...
Just upgraded my system to new PC with Vista on it. Can't find my original Canon Multipass F50 discs to load the drivers, etc. Can I find this online somewhere? AND is this compatible with Vista?
Unfortunately Canon has decided not to create a driver for the F50 that is compatible with Vista they feel it would be too expensive to create a driver for an old model like the F series.
Sorry
Sep 23, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Have a Canon F50 Multipass. The alarm light is
Attempt to re-surface any replaceable rollers with a brillo or Scotch Bright pad ONLY if you are unable to locate replacement rollers. This will reduce the life of the rollers further and can permanently render them defective
Any rollers in the paper path and in the tray area(s) should have texture and should not be glossy or completely smooth with the exception of hard-plastic rollers used only as guides.
Apr 28, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon Multipass F50 prints too much Yellow on photos
try realigning printer heads using the allingment on ya software look thru the printer manual to see how to hope this helps
Apr 12, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Looking for a canon f50 multipass reference manual. Reason: trying to use flatbed scanner to scan - not the automatic document feeder. automatic document feeder works. The article I wish to scan does not...
To scan from the platen glass:
1. Click the "Setting" icon on the multipass toolbar
2. Select "Toolbar Settings" tab
3.Under "Image Source", click the "Scan From" drop-down menu and select "Platen"
Mar 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Some lines are blurred, Some lines are printed larger, Some lines
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 02, 2009 | Canon MultiPASS F50 All-In-One InkJet...
Canon MultiPASS F50 won't copy but will scan
Does the copy function work if you place the document to be copied on the platen (open the cover and lay it on the glass)? If so, check the area to the left of the platen. There should be a strip of glass with a clear plastic cover over it. This area is used for scanning when feeding paper through the automatic document feeder (ADF) from the top. This area must be clean. If this area is clean and clear, it's possible that the scanner element (below the glass) is no longer going all the way to the left when using the ADF. This would be a problem that would require servicing.
Oct 15, 2008 | Canon MultiPASS F50 All-In-One InkJet...
Wrong cartridge messsage
Hi, Please follow :
1. Reseat F30 / F50 print head 2. The Print Head may need replacing - F50 3. Press ON/OFF switch to reset the multifunction device 4. The F50 may require repair
You can see exactly how to perform these steps with pictures at this link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=6324
Go to this link if you are unable to find the"Wrong Catridge" link
then you need to type "wrong cartridge " in the small search box on the website.
If the website asks you to select
"Category.=Multifunction"
"Product Type =Inkjet"
"Model= Multipass F50"
Cheers
Jun 04, 2008 | Canon MultiPASS F50 All-In-One InkJet...
HUH
Please don't take out my answer on my rankings. I just pass on what I know. Microsoft-certified Windows Vista drivers are not available for the MultiPASS product you are inquiring about. However, you may be able to install an emulation driver and set the machine to Printer Mode that will allow use of your product as a printer in Windows Vista. If you decide to use the Printer Mode function, please be aware that the instructions and support are provided as is and Canon does not guarantee compatibility or print results.
Note:
  • To print using Printer Mode, the printer must be connected via a parallel port connection. A USB to parallel port connection is not recommended.
  • Installing the emulation driver for your product will provide print functionality only. The scan and MultiPASS F50 fax driver, as well as the MultiPASS Desktop Manager and Toolbar, will not be installed and are not available in any Windows Vista environment.
If you need or want an emulation driver I can help. Sorry, please don't rate me bad for news. If you need more help on this just add a comment and I'll be there!!
Mar 16, 2008 | Canon MultiPASS F50 All-In-One InkJet...
MultiPASS F50
check the Canon Knowledge base at www.canontechsupport.com, it may be the printhead or unit itself.
Oct 23, 2007 | Canon MultiPASS F50 All-In-One InkJet...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
64 people viewed this question
old marine
old marine
