Question about GTCO CalComp ScanPlus III 800T
Scanner will not power up
This problem came up before, and after I left the scanner turned off for a few days it fixed itself. This time, it powered down while I had it turned on for a couple of hours, and it won't come back up. I took the cover off the end close to the power plug and did a few rudimentary voltage tests. The switch and fuse are fine.
  • 1 more comment
  • pyaresquared Jan 14, 2009
    I have had a blown bulb before. When the bulb has blown, the paper drive mechanism still worked. This time the drive will not work. Would a bad capacitor(s) create a previously intermittent problem? Or would it just fail and be done with it?
    Are there any wide-format scanner repair shops in the Phoenix area since CalComp GTCO closed down? Repairing the power supply unit may be too much of a challenge for my limited electronic skills.
    Good wide format scanners cost several thousand $$--even used ones. I want to try to fix this one.
  • pyaresquared Jan 15, 2009
    I will take a look at the boards and capacitors. Thanks.
  • 716 Answers
This Is What Yellow Book Suggested. Click Here
Posted on Jan 14, 2009
    Sergeant:
    Novelist:
  • 326 Answers
On the main board og the scanner there are white cables connected any 1 out them can be faulty that needs replacement.also check out for the bulged capacitor or leaked capacitor on the circuit board.
    Sergeant:
  • 221 Answers
Its just the faulty circuit of the scanner.the circuit is blown.and it needs to be checked with a meter to get the faulty capacitor.its a costly issue.as if its too old replacing the scanner is good choise.
  • 19,396 Answers
Test also the bulb, if the bulb has blown, then it is likely a fault on the board that powers the bulb with ac.
If the bulb is ok, you need to test the psu capacitors , and fix the power supply circuit, or if this is on a separate board, replace the board.
Also test power cord , and try a different AC socket.
  • Ginko
    Ginko Jan 14, 2009
    "When the bulb has blown, the paper drive mechanism still worked" :
    I know it , I told you : " if the bulb has blown, then it is likely a fault on the board that powers the bulb with ac"
    You have read only first three world from my post.
    Regarding the repair, it is better not to repair a scanner like this just anywhere.
    Call l Fred Bryant at GTCO : 480-443-2262 they will send you an onsite engineer from nearest repair point.
    Also ask information about getting a service contract.
    Repairs for this machine are expensive.
    Here is GTCO contact page:
    http://www.gtcocalcomp.com/supportscanne...
    Thanks
  • Ginko
    Ginko Jan 14, 2009
    Addon: regarding the bad capacitor, yes, the intermittent faults that at start you fix by unplugging, and then prevent unit from starting can be typical of a capacitior starting to fail, then failing completely on a power board.
    First test the main PSU, that is most likely, then test the inverter board that is powering up the lamp, a badly shorted inverter can cause shutdown.
How do I fix our Printer?
Tebogo,
This sounds like a power supply problem to me.
I would get in touch with Xerox concessionaires as soon as you can it could be a faulty power supply or one which needs upgrading perhaps. If it's not too old then I'm sure theres a fix.
Good luck.
Apr 30, 2015 | Xerox Phaser 3635MFP/X Multifunction...
Lamp shuts down during warm up cycle!
My belief is that it would be inside the scanner itself. In transparency mode the lamp may require more power and shutting off is a safety device if something is failing. Sadly, repairing a scanner costs almost as much as buying a new one.
Apr 24, 2014 | Canon CanoScan 9950F Flatbed Scanner
Canon image runner2200 error e000202-0001
this is error related to scanner section. The home position sensor of scanner ( copy lamp ) doesn't go of when the lamp is in home position.
You can try to manualy, few times slide the scanner rail to right and left side - BEFORE TURN THE POWER OFF AND UNPLUG THE COPIER FROM OUTLET.
If the sensor if really faulty you need to replace him.
Call service!
Sep 13, 2011 | Canon imageRUNNER 2200
MFC8860DN SAY'S SCANNER LOCKED?? WHAT'S THE FIX??
Hello my friend.If you open the scanners door under the document cover is one switch that locks and unlocks the scanner.Move it to the position that shows that is unlocked.If this doesnt work it means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This should fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remove the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable . After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp more into the scanning area and repeat until works.
Feb 09, 2010 | Brother MFC-8860DN Printer
LED never gets to on solid. Always flashes slowly as if in operation.
Thanks, but the problem fixed itself. After leaving the scanner on for a very long time, the LED finally started to glow steadily. Now after power cycle it only takes a few seconds to become ready.
May 02, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Scanner turning itself on and off??
I do not think u should try to fix it as it would void the warranty since your scanner is only 8 months old. Get it fixed by returning it to the vendor.
May 24, 2008 | Microtek ScanMaker i800 Film Scanner
HP Officejet all-in-one
This issue seems with the scanner mechanism of the all-in-one. Once try to make a copy and check the result, of it still says scanner failure, then connect the all-in-one directly to walloutlet and then power cycle the all-in-one and then reset.
May 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scan head/carriage not parking in one spot -- keeps moving.
The scanner is having trouble getting its "white reference" usually due to dusty mirrors, but can also be the bulb losing brightness. These are not a easy machine to pull apart if your not used to it.
Good colour laser MFP, depends on volume of prints and remember colour dont come cheap, but dont use refill cartridges, Kyocera and Oki both have good Models
Dec 01, 2007 | HP LaserJet 3320mfp All-In-One Printer
Wont Turn On
Try moving the power supply connector around.
Jul 10, 2007 | Radio Shack Pro-2018 Scanner
No image
I had the same problem and I figured out how to fix it. First I unplugged the scanner. Then I bit the cables in half. Next I hit the scanner as hard as possible with a hammer. Then I put it on the floor and jumped on it a few times. After that I covered it with gas and set it on fire. Finally I peed on it as it burned. Then I got a new scanner- an HP.
Mar 26, 2007 | Epson Perfection 1670 Flatbed Scanner
GTCO CalComp ScanPlus III 800T Logo
65 people viewed this question
Top GTCO Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a GTCO Office Equipment and Supply Expert? Answer questions, earn points and help others
