Question about Whirlpool LER4634J Electric Dryer
My dryer does not turn on no power
At first the dryer stoped heating up then it started heating up for a week and know its not turning on at all
  • 979 Answers
This could be a t stat going bad. Check first the breakers, then the wiring in the back of the dryer. There may also be a problem in the thermal fuses which are located underneath the top of the dryer.
Posted on Jan 14, 2009
Creda 37761 problems drum will not turn heating up
OH OH SOUNDS LIKE BAD WINDINGS ON THE MOTOR, HAD THIS PROBLEM LAST WEEK , THE MOTOR WAS SHOT AND WOULD NOT TURN THE DRUM, I TESTED IT WITH MULTIMETER AND MANUALLY, BY OPEING UP AND TAKING BODY OFF THE DRYER, remove the drum and belt, JUMPING THE DOOR SWTICH, AND THEN STARTING THE DRYER, BINGO It the motor STARTED RUNNING, but when I put body, drum and belt back on BINGO no running or turning.
Sep 14, 2014 | Dryers
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
Nov 10, 2013 | Whirlpool Cabrio WED6400SW Electric Dryer
I have have an older kenmore electric dryer that won't start. Let me give you some detailed information about the events that happened prior to the discovered failure. -This dryer hasn't been used for a...
The heat is not a factor.Make sure you do not have a tripped breaker. Otherwis if you had a power surge to the dryer, ther could be electrical damage.
Aug 11, 2010 | Kenmore Dryers
Dryer stoped working fuse is good power soruce good just no start
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2010 | Dryers
GE dryer makes loud huming sound wont start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 25, 2010 | Dryers
My dryer stoped working. I replaced the push to
Dryer2_bing.gif Repair ? The dryer will not start
heatman101
May 10, 2010 | Kenmore 63952 Electric Dryer
Hotpont/Zanussi Electric dryer TC7102W no timed heat
it seems thatyour getting no heat on the permanent press and gentle cycles correct? if we know the heater is working that takes care of a number of possible causes turn the power off and remove the rear panel of the dryer. you will see a couple of thermo disks mounted on the heater box.you probably will find tons of lint on these thermostats and what happens is you turn your dryer on low heat or automatic cycle where the dryer will run until it senses the clothes have no more humidity inside the drum every time the thermostat shuts off the heater the dial moves a little closer to the off position. if there is a build up of lint around these sensers the dryer will heat up until the sensers turn the heat off. what happens now is the thermostats are nice and warm as the lint buildup iacts like an insulator preventing the thermostat from calling for more heat so it will take forever to dry a load of clothes. brush the lint off the thermostats and while you are at it vacuum the back of the dryer there should be a lot of lint there
Jan 23, 2009 | Zanussi TC7102W Electric Dryer
GE Dryer timer stoped working and so it runs and runs
Dryer knob assembly unit is faulty and loss of heat sounds like an element going out.
Dec 10, 2008 | GE DBSR453EBWW Electric Dryer
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
53 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
