Question about RCA RP3721 Clock Radio
RCA RP3721 Alarm won't shut off
I work in a building and the only radio that could pickup AM radio is my RCA RP3721A but somehow I cannot get the alarm to be off. How to turn th alarm completely off? Regards, Tino.
  • Anonymous Jun 19, 2008
    I am unable to reset the alarm
To turn alarm off completely, press WAKE1 and WAKE2 until the bell-shaped indicators go off.
As for resetting the alarm (buzzer), press SET WAKE/CLOCK untill SET and WAKE! light.  Press left- or right+ arrow to set time.  Press WAKE1 until bell-shaped indicator comes on.
Posted on Oct 24, 2008
SOURCE:
User manual
You can download the manual at this link;
http://www.manualowl.com/p/RCA/RP3721/Manual/54944
Sep 12, 2013 | RCA RP3721 Clock Radio
User manual alarm
You can download the user manual at this link;
Jun 20, 2013 | RCA RP3721 Clock Radio
How to turn on radio
Just press the larger On / Off button, lower left side of clock, select AM / FM band (make sure you install either the am band wire antenatal and the FM antenna (comes with clock) use the rocker arm switches to search out stations and adjust volume by turning knob on the right side of radio, that's it... (0:
Mar 31, 2013 | RCA RP3721 Clock Radio
Can't read fuction
Check the backlight LED voltage to display unit.
Mar 28, 2012 | RCA RP3721 Clock Radio
Do you have the user manual for an RCA Clock radio rp3721A?
You can download and print the instruction manual in PDF format by clicking this link.
On the page which opens, click on the "Download" button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 12, 2010 | RCA RP3721 Clock Radio
Snooze timer
Well, unfortunately the snooze period is apparently preset on the RP3721 and cannot be changed.  The user's guide says that it is approximately 9 minutes long.
Feb 18, 2008 | RCA RP3721 Clock Radio
Setting a Radio Station for Wake Up
You can download the manual from the link below: http://157.254.235.130/public/RP3721%20EN.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 30, 2007 | RCA RP3721 Clock Radio
Water damage
Then get it repaired.
Aug 15, 2007 | RCA RP3721 Clock Radio
RCA alarm clock - RP3721 - crystal or AC for time?
They used to use crystals to help the timer ics to keep time but since the development of Micropros. all this is built in to one chip. Now they will use a resonator or a small crystal for the timing clock of the micro but nowdays the manufacture uses that clock to keep all in check. If your gaining time you probably are having problems with your ac duty cycle as this also keeps clocks in check.. This would not affect most devices but could be a problem. But of course a defective Micro could also cause this gain in time And probably is?? Now a battery backup is nothing more then a battery in line with the Microproccesors B+ terminal through of course a diode as well as a voltage limiter resistor to take over the B+ when the units ac supply is absent..
Mar 03, 2006 | RCA RP3721 Clock Radio
RCA RP3721 Clock Radio Logo
597 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
