I hav a armstrong direct air furnance and when i call for heat the burners stay on for about 10 secs then go out and after the 3rd try it shuts itself off
  • 306 Answers
Sounds like the flame sensor is dirty. Carbon builds up on the surface and it just takes a very small amount to block the sensor. Take some steel wool and very gently clean the surface off. The sensor is located at the last burner in line. Looks like a thick piece of wire just sticking down. Let me know how it goes. ken
Posted on Jan 15, 2009
Tip
How to make sure you Heat is working
A common problem with a furnance is the furnance will attempt to ignite, several times, you will notice that the house is not heating properly. You will hear the furnance come on and you will assume the heat is on, and the house will continue to be cool. You wiil check the furnance and you will hear it start up and the blower will come on, however a few seconds later after you have walked away the blower will shut down and there is no heat on at this time. You will again go check the furnance and after the furnance start and go through the cycle the furnance will shut down you will notice that the furnance has indeed shut down. This is the common problem of the flame sensor, you will have to remove the flame sensor, get a small piece of fine grade sand paper, and remove all the black colored carbon from the flame sensor until is is shinning bright, replace the flame sensor and attempt to start the furnance. You will notice that apatment or house have reach the set temperture, that the furnance has went through its cycle and the furnance will ignite and stay on continueously until the house obtain the preset temperture..
on Dec 13, 2009 | Heating & Cooling
Burners turn on for 10 sec and shut off
going out on safety. either high limit or failure to detect flame.
Dec 14, 2013 | Ruud Central System Air Conditioner
Kitchen aid dryer / heat flame not staying on after 20 secs
Sounds like your gas valve is fine, if it comes on at all, its good. A air flow restriction would cause a overheat condition and shut down the burner. Once it cools back down the burner would re-ignite and repeat the cycle. The sensor on the left of the burner is the flame sensor and the flame wouldn't come on at all if it was bad. You've already changed the coil kit so the valve is fine, disconnect the vent from the back of the dryer and see if the problem goes away. If the problem stays, I would suspect the thermostat. Good luck.
Mar 16, 2010 | KitchenAid Dryers
Flame wont stay on, runs for about 5-10 secs and
usually the thermocouple wears out. Make sure the thermocouple is in the flame, if it is, and it still wont stay lit I would change that first.
Feb 28, 2010 | Mr. Heater MH175KT Open Flame Utility
My gas furnance will not stay on
This is probably the thermocouple that makes sure the flame is ignited. they can be cleaned with sand paper usually. it is located beside the burner within the fire. It will be very hot!
Apr 08, 2009 | Honeywell Electrical Supplies
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
