Question about Wurlitzer ONE MORE TIME CD Shelf System
Unable to pinch CD, when selection is made.
Setup is fine, when a selection is made the carriage does not travel far enough across to pinch CD.
  • Wurlitzer Expert
  • 567 Answers
Email e for manual and service programme philhemmings@hotmail.com
Posted on Sep 25, 2010
  • 98 Answers
I may be able to help you. Is this the Wurlitzer princess jukebox which holds 120 CDs? If so, the problem is most likely with the clamper which opens and closes to grip the CDs. If so, email me and I can give you detailed troubleshooting information and repair advice. Rod Stebelton, tech@wurlitzer-ohio.com.
Posted on Dec 24, 2009
I have a "unable to
Any of the 30 series errors say that the carriage is not free to move from side to side across the paper. You need to look close on each side of the machine where the carriage travels to see if there's a paper scrap stopping it. Also the encoder strip could be out of the slot in the carriage assembly. If all is OK you need a shop repair to determine if the logic or carriage pcb's are OK.
Apr 11, 2011 | Brother MFC-845CW multi-function...
Give me solutation of errore 36 came inb DCP165C Brother Printer
That error 36 - means "Head/carriage unit travel error" , if the printer is still under warranty, have it serviced. But if its out of warranty try to find any obstacles on the travel path of the head/carriage unit. If you cant find anything, it only means you need to replace some parts.
1. carriage PCB
2. head/carriage unit
3. CR encoder strip
4. carriage motor
5. main PCB
6. power supply PCB
7. maintenance unit
May 13, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother MFC-6490CW printer error unable to print 36
Feb 09, 2010 | Brother MFC 6490CW InkJet Printer
Where is the carrriage located on my hp 7310 officejet printer?
The carriage is the unit that holds your ink cartridges, usually parked on the right side. When you have carriage stall or carriage jam you usually need to clean the clear plastic strip that runs across behind the carriage assembly, and make sure there are no scraps stopping the travel of the carriage.
Dec 24, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My typewriter keeps binding up and will not go far enough across
Most likely, the problem is not with the margins. The most common fault (loosing margins) is caused by the carrier binding on the shaft that it travels on. Solution:
Turn off the power
Locate the shaft that the carrier travels on (usually about 1/2 to 3/4 in. diameter, chrome shaft in the middle or lower/rear of the open area that the printer travels back-and-forth in).
Apply a few drops of 10 weight oil acroos the shaft and wipe with a cloth. Move the carrier manually to the right side of machine and repeat the prosess on the left side of shaft. Lubricate some more and repeat the process. NOTE: 3 in 1 oil is OK. . WD 40 IS NOT
Nov 11, 2009 | Smith Corona Office Equipment & Supplies
Brother MFC-5440CN, unable to print
Unable to print is usually a paper jam either in the far right or the far left of the carriage assembly, you need a flashlight to inspect for paper scraps caught at either end of the carriage travel area.
Sep 04, 2009 | Brother Multi-Function Center MFC-240C...
Setup was unable to verify drive C:.
hi ;
this sems to be a memory problem;
in bios , try to decrease the memory for your card to resrve a memory space for the installation program,
if this does not work , it might be your VGA card.
Mar 11, 2009 | Computers & Internet
Fairley new opener but it unhooks from the Carriage Assembly once every 5th time
sounds like the carriage is coming of the connector and that usually happens when the cariage travels to far and bumps the power head of the machine that split second **** is enough to unhook it fro the carriage because the next motion would be coming down and probably without the door attached to the connector , and by connector i mean the other half of the carriage Remedie ;; adjust the open door travel to not come up as high let it stop about 2 inches before the machine and that should fix-it , Thank you and hopefully i was able to help you please leave a good rating if i was able to help Sincerely Glenn Mayer ....mayer overhead door co,
Mar 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Machine will NOT work
If the print carriage is stuck on the far left, gently try to turn the gears a few turn and if you are lucky enough the print carriage will go back to the right.
This is what I did and it is working fine now.
One thing importan, be "gentle" it is easy to break.
Apr 08, 2008 | Victor 1297 Calculator
Wurlitzer ONE MORE TIME CD Shelf System Logo
177 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
