Question about MSI KM4M-L Motherboard
Memory Problems (MSI KM4M-V Motherboard)
My motherboard is an MSI KM4M-V, and should be able to accommodate 512MB of RAM.0 DDR RAM (DDR-333). It has motherboard has two slots for memory cards. One slot is currently empty, while the other has a 512 MB PC2700 DDR333 with a chip configuration of 64x64….the memory that came with the computer. To increase my memory, I recently decided to buy another 512 MB PC2700 DDR333 memory stick/card with the 64x64 chip configuration. This new stick/card works by itself (i.e., when I remove my existing memory stick/card), but it will not work in conjunction with the existing stick/card. In other words, the two don't work together, but each works on its own.
At that point, I started thinking that I'd simply buy a 1024MB stick/card. I was thinking that maybe the two 512MB sticks/cards won't work together for some strange reason, so I'll just buy a single 1024MB card. The 1024MB card, also, did not work. This lead me to think that the motherboard, which is rated to handle 2GB of memory, will for some reason only accommodate 512MB. I took the computer back to the place that put it together for me three years ago. They were stumped. As far as they were concerned, the motherboard was doing something it shouldn't be doing. I've done some investigating and have determined that I may need to toggle with the bios (memory voltage and/or memory timing). Anyone have suggestions on what may be the problem and what I can do to fix it?
  • 903 Answers
If you know the make and model number of the memory sticks you will need to contact the manufacturer to find the voltage specifications so you can adjust the bios accordingly. Or do a google search with the model number and make of the memory stick for voltage details
Posted on Jan 14, 2009
I have a Pentium 4, 2.66Ghz processor with 848P-A7 motherboard. I purchased hynix 2GB DDR400 SDRAM PC3200(2X 1GB RAM KIT) to replace my 512MB DDR. Why does it not work ? Spec Says that it supports...
Hi dont know why new RAM dont work, may be faulty. Go to www.crucialmemory.com
Let them scan your computer and they will tell you what memory slots you have and what memory you should be able to use
Jan 23, 2011 | EliteGroup 848P-A7 Motherboard
I have a KBV-MX motherboard and need to know if the 512MB Kingston memory (KVR400X64C) will be compatible.
Yes Kingston Kvr400x64c 512 MB will be compatible with your motherboard. The Ram form factor and speed supported by your motherboard are PC3200, PC2700, DDR266/PC2100 and DDR400/ 333/ 266, ECC, (non-ECC and ECC).
And the Kingston kvr400x64c 512MB is DDR 333 Non-ECC.
Hope this clears your doubts.
Ram details here (Click here)
Motherboard details (click here)
Good luck.
Thanks for using FixYa.
Nov 17, 2010 | ASUS K8V-MX Motherboard
Mother board problem
Unfortunatly this board does not have DDR2 support, it supports DDR 400/333/266 memory inetrface and up to 3 Gigs. Memory banks are for 184 pin Dimms.
Apr 02, 2010 | MSI Mother Board (MSM865PEN2V) Motherboard
Upgrade
According to motherboard manual (p. 2-9), it can support upto 2GB of DDR400 RAM int total. You can get the manual from http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=565.
Dec 21, 2009 | MSI K8T Neo-FSR Motherboard
How mutch RAM does "Motherboard MSI PM8M3-V (MS-7211 v1.x) Micro-ATX" supports
Spec sheet shows you can run 2GB of PC2700 DDR RAM (DDR-333), or PC3200 DDR RAM (DDR-400); http://www.superwarehouse.com/MSI_PM8M3-V_Micro_ATX_Pentium_4_Motherboard/PM8M3-V/ps/727805
MSI also provides a list of tested memory for the board;
http://www.msi.com/uploads/test_report/TR10_234.pdf
Hope you find this helpful!
Mike
Oct 12, 2009 | MSI PM8M3-V Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
Install DDR-DIMM PC3200 to MS-6367 MSI
That motherboard was made for PC2100 DDR266. A PC3200 DIMM *SHOULD* be backward compatible. Depending on the density of the PC3200 memory you might have problems. If you have not bought the memory yet I would go with the PC2100 for sure since the PC3200 will give you no speed gains at all and will be running at PC2100 speeds anyway.
If you already have the PC3200 memory then I would say just give it a shot. The worse case scenario is your machine will not boot up with the higher speed ram installed. Assuming you take all the normal hardware upgrade care and do not physically break anything you can test this memory with no harm to your motherboard.
Aug 12, 2009 | MSI MS-6367 Motherboard
Replacing existing DDR RAM
Well this that you can use PC3200 DDR 1GB then those you mentioned above ... and let me tell you there is only bus speed difference between ..
Jun 23, 2009 | MSI 865P Neo (MS-6742-020) Motherboard
Adding ram
Supported RAM TechnologyDDR SDRAMRAM Installed ( Max )0 MB / 2 GB (max)Supported RAM SpeedPC2100, PC1600, PC2700The above is the specification for RAM for your M/board
It can take up to 2Gb ram 2 X 1GB sticks you may have to change BIOS settings aand your computer will definitely run fasterPlease give me a FIXYA
Sep 13, 2008 | MSI KM4M-V KM400 SocketA 333FSB 2DDR...
KM4M-L and graphics cards/memory queries
I would hate to burst the bubble but if you buy any DDR2 memory, then you will be wasting your money.
This motherboard only supports standard DDR upto 333mhz and only 2gig max of that.
Video card wise, then an ATI 9800 Pro can be had cheaply or an nVidia 6800 AGP version can be purchased new.
Hope it helps =)
Apr 12, 2008 | MSI KM4M-L Motherboard
MSI KM4M-L Motherboard Logo
411 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
