Question about Mag Innovision LT576s 15" Flat Panel LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
When I turn on the monitor it displays the image perfectly for about 30 seconds during which there is a slight buzzing sound. Then the screen goes black with just a faint ghost of the image on the screen. Once the screen goes black, the buzzing stops. I bought the monitor used (the guy said it worked perfect and had no defects or problems) and it has a universal 12VDC power supply that came with it. The back of the monitor says 12VDC 4.0A so it should compatible. It did not come with a vga adapter so I'm using a replacement shielded vga m/m adapter. I've tried the monitor on my desktop computer and on my laptop with the same results.
  • Losi Dec 03, 2007
    What is the LOT of monitor? Please let me know
    Losi
  • Losi Dec 04, 2007
    I have an IBM LCD screen which displays perfect image for about 15 or more seconds and then went blank. The power green LED remains green. Removing the vga cables indicates fine that no signal is not available and the power LED goes orange.
I have an IBM LCD that shows perfect image for 15 seconds or more and then goes blank. any suggestion how I can pin point the problem.
Posted on Dec 04, 2007
  • 193 Answers
Replace the monitor. CRT monitiors are CHEAP! large screen CRT are easier on the eyes and CHEAP! you should not need a vga adapter, use the computers video, if its an on board. good luck. Canada.
Posted on Jun 24, 2007
I hope the problem will be in LOT of the monitor...you need to replace the LOT
Posted on Jun 15, 2007
One day it went black, if I turn it off then on I can see a perfect picture for half a second
If this is a LCD monitor, most likely the invertor or the bulb is not working correctly. If you shine a flashlight at the monitor you should be able to see the image. What has happened is the back light is not lit to display the image. If you are handy at repairing electronics you can swap invertor and bulb from the other monitor if they are the same model and size. It may require some soldiering though.
Dec 07, 2016 | AOC Computers & Internet
Screen goes black but sound is good.
This sounds like the inverter which powers the display fluorescent has or is failed/failing. If you take a torch to the blacked out display can you see the image faintly? If so the unit needs repairing.
Mar 12, 2015 | Televison & Video
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Hannspree HF229H will not stay on
railbird56, Common problem for ALL BRANDS of "cold-cahtode-fluorescent-lamp" back-lit lcd monitors! Here are your options!!! Cheapest to most costly!! 1. Warranty repair. 2 DIY repair???? 3. Local or distant repair. 4. possible old + cash swapout with Hannspree for refurbished same model?? 5. Trade-in for new wide screen. My best guess on your monitor (no history) is that the unit's SMPS is in partial or full shutdown mode during it's black screen moments. How much do you know about "electronic ballasts" "switch-mode-power-supplys" and how to repair them?? 12fixlouie
Feb 22, 2010 | Hannspree HW191D LCD Monitor
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Screen comes on then goes out in 5 seconds. The backlight goes dark but the seen is working, just can't see it. The backlight is out...
mark587, Did you shine a very bright flashlight 1" from the screen to try and see the WIN-desktop ?? Even though the screen appears BLACK. Your words above said: JUST CAN'T SEE IT Did you really NOT see anything? Have you seen any of the longer video clips of "LCD Monitor Disassembly" on YOUTUBE? Some BLACK screen "symptom" lcd displays can be repaired for less than $10 in parts. Capacitors! Also check videos on lcd repair. Then get back here to fixya and I or any of the guys can help you decide what to do with your display whoose screen is now dark and lifeless. After doing the YOUTUBE thing you may even tell us what you will do!!! Hope this was helpful. Yes we do want to hear back from you. please rate this response on fixya. I'm louie12fix on fixya or lmistyrel @ aol.com. Bye for now.
Oct 07, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
When I turn on my computer and monitor, the monitor display is on for about 30 seconds, then goes black. The computer is on, the green light is on, but nothing on the screen.
get a bright light or torch and shine it on the screem if you see any faint image then the problem lies with your backlight, sometimes connectors come loose and thats your best hope. if you have a warranty of any kind its time to use it.
Sep 28, 2009 | Mag Innovision LT776s 17" LCD Monitor
I have a FPD 1830 flat screen monitor not displaying picture
Send the monitor. It's a power supply problem. My 15.4" LCD has the problem, too, whenever I move the monitor down, it powers off, and the menu disappears as well, but I'm going to fix the screen.
Jul 08, 2009 | Gateway Computers & Internet
My monitor keeps going to a black screen a coulpe of seconds after being turned on
Video (picture) must be constantly entering a monitor for a monitor to continue to display a picture after it self tests (goes on for a second or, two) Your monitor is fine; check it using another known good computer.
May 20, 2009 | Vision Computers & Internet
the 12V is for speakers.. the 245bw takes regular 120V AC (same cord as your computer)
the buzzing is annoying, though. i don't know if it's a "feature" or just a side effect.. ie, if i could take the case off and poke around, i would. 4 times out of 5 it's some dumb piece of tin reverberating from a transformer or something..
Dec 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Mag Innovision LT576s 15" Flat Panel LCD Monitor Logo
501 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
