Question about Sony Grand WEGA KF-42SX300 42" LCD TV
Lamp Needs Replacing
Hi
i was hoping if you could advice where i can get a diagram to shw me how to remove the lamp and replace it from my sony 42sx300
regards
Sid
  • 1 more comment
  • sayuk Jan 14, 2009
    i sorted it many thanks can you please tell me where i can buy the lamp from? for less than £100
  • Anonymous Jan 26, 2009
    Sony Grand WEGA KF-42SX200u it does not switch on
    Sony Grand WEGA KF-42SX200 42 in. LCD TV, \It has power but no display on screen.
    Thankyou
    Amit
  • 90 Answers
Most Sony DLP lamps are located in the front behind the control panel. There are some oversized thumb screws on the back right and left edges with a flathead slot in them. Once unscrewed, the front panel will pop off. (sometimes you have to pull pretty hard) once in...there will be a couple more screws and the lamp has a handle to pull it right out.
Posted on Jan 14, 2009
Stony LCD 2007 goes off and screen comes on saying it needs projection lamp. Is this something I can replace myself ?
Yes, the lamps are made to be for most models replaceable by the owner.
Most the lamp is located up front behind the cover below the screen (Model number?) and you remove a door, back out two (usually Allen bolts) and the whole cartridge with lamp pulls out (has a handle).
To get a idea of lamp price Google the model number with "lamp".
You Tube has video instructions for replacing the lamp for most models---Get a original Sony replacement and not a generic one.
Bulbs are sold either loose or the whole thing with the cartridge--get the cartridge as easy to replace.
May 29, 2012 | Sony Televison & Video
AsI have a sony kds55a2020 tv, I recently replaced the lamp because the lamp light was on. after I replaced the lamp, the tv power blinks 4 times and never comes on. what else can it be?
hi,
Check is the lamp is properly installed or not. If the tv was at working condition before replacing the lamp then then the new lamp is not properly installed. Check one more time. If you can then just remove the new lamp and insert it again. Make sure that the lamp is properly attached. And then check.
ok
Jun 11, 2011 | Sony KDS-55A2020 55" Television
Replacing lamp
Lamp replacement procedure is written in user manual,check page-17
Click Sony Support to download free copy of user manual of KDF-60WF655 if required.
There are two thumb screws at lower corners if you see tv from rear, remove these screws and take out lower front panel, in center of that space, you will see lamp cover, remove it and unscrew old lamp, pull it out and put new lamp then put things back in reveres order.
Required lamp of KDF-60WF655 is available in Sony Accessories Store for $200 under part number XL-2200
Hope these info will help you.
Thanks.
May 13, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony color sucks model kdfe42a10 piece of
Please follow the instructions below to check that sometimes the lamp cove does not properly closed,
1. Remove the Lamp Cover.
2. Turn the lock to the OPEN position to release the Lamp Door and remove.
3. Pull out the Lamp Assembly, then reinsert the Lamp Assembly until it is locked into place.
4. Replace the Lamp door and turn the lock to the CLOSE position.
If the problem persists then you have to replace the LAMP Assembly, For estimate contact any nearest SONY SERVICE CENTRE.
Thanks for using fixya.
Nov 17, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony LCD Projection tv - picture and sound goes out periodically
The Lamp is designed to be replaced by the customer. The Lamp Door is on the right side of the set as you look at it from the front. You Must first remove the cover, then turn the handle of the Lamp Door counter clock wise. Pull the Door out. The Lamp is now exposed. Lift up on the finger loop of the Lamp and pull.
Replace in reverse proceedure. The Lamp can be ordered by calling Sony at
1800-222-SONY.
Hope this Helps,
Skyassoc
Jul 03, 2009 | Sony KDF-E55A20 55 in. LCD Television
I have replaced the lamp.Now the lamp wont come on and tv shutts
Did you replace the lamp cover after replacing the lamp? Make sure the cover is properly installed.
Jan 21, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony KF-42WE610 Replacing the Lamp
There was another fastener which was troublesome, but with some carefull work I was able to pop it out with a long screwdriver
Jan 10, 2009 | Sony LAMP BLOCK XL2100U Projector Lamp
Hi there
Yes the lamp light means change the lamp. If you have not changed one in this tv yet it is overdue.
Jul 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hi there
turn set on with lamp in and lamp cover also,and after tryin to tur on ,red ligh its going to start flashing a segment of times.
Let me know how many times is blinling?
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Removing the "lamp needs replacing" warning message
Hi guys
Firstly you need the remote to reset the lamp timer.
Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
Jul 31, 2007 | Sony VPL-EX1 Multimedia Projector
Sony Grand WEGA KF-42SX300 42" LCD TV Logo
201 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
