Question about Kenmore 63942 Dryer
BEST WAY TO LOCATE HEATING ELEMENT
HOW DO I GET TO IT
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Need make and COMPLETE model number in order to determine how your dryer is configured. All dryer's are not manufactured the same, and the heating elements can be in different locations.
  • Kenmore Master
  • 8,220 Answers
How do I chech the voltage atthe heating element on my GE JBP66 stove
Remove the heating element, get a multi meter set it to 200-500 volts AC. Next locate the slot where the heating element came out of and put meter leads in the holes, turn on switch for the element in question.
Sep 02, 2014 | Kitchen Ranges
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
How do I check my hot water element?
1)Locate the upper heating element in the top access. The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to the disk.
  • 2)Set your ohm meter to the X1 or RX 1 scale to measure the continuity of the heating element. Touch each of the ohm meter probes to each of the terminal screws on the heating element. A positive reading indicates a good element. If there is no reading, the element is faulty.
  • 3)Test for a possible short in the heating element with the ohm meter. Touch one ohm meter probe to one of the heating element terminals. Touch the other ohm meter probe to the bracket that secures the heating element. If you get a reading of zero, the element is good. If there is any positive reading on the scale, the element is grounding itself and will require replacement.
  • 4)Test the lower heating element exactly as the upper heating element.
  • 5)Place the access doors back on the water heater tank, and secure them with the screws.
  • Good luck
    E.CUADRA
    Dec 03, 2011 | Heating & Cooling
    Heated seats dont work
    Its hard to say without looking at it in person. sounds like you have a electrical short in the wiring systems or blown fuse bad switch. The heating element in the seat could also be burnt out and need replacing. best thing to do is locate the wiring system underneath the seat and test the current if any going into the seat heating element. if you do get voltage/current following, then the seat element is bad.
    Nov 09, 2011 | 2006 Chrysler Town & Country
    Bra wire stuck in drum
    Tricky one there. Anyway, best way to tackle that is to locate the heating element and remove it. The bra cup spring normally locates itself against the element. Look in the element cavity with a torch and you will normally find it while slowly turning the drum. Use a long type of extraction pliers and remove.
    May 25, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
    Does not heat- three of the temp sensors read 0 ohms, one is at 7.4 K ohms. Can it be the cause
    Hello there
    Here is a list of item for you to check Hope this is very helpful for you
    Best regards Richard
    My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
    Proper Voltage
    If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
    dryer_heating-element.jpg Heating Element
    It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
    dryer_thermal-fuse.jpg Thermal Fuse
    Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
    dryer_thermostat.jpg Thermostat
    If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Dec 15, 2009 | Whirlpool LTE6234D Top Load Stacked...
    How to replace heating element on dryer model #96282100
    This is a fairly simple procedure. Just follow these steps:
    1. UNPLUG the dryer. Dangerous voltage is still present even with the dryer turned off.
    2. Turn the dryer around so you can access the rear and remove the exhaust vent hose.
    3. Locate and remove the screws around the perimeter of the dryer back panel and remove panel.
    The dryer heating circuitry will be located on the right hand side (as viewed form the rear). The heating circuits consist of the following components:
    Heating Element - (part number 660982)
    *Thermal Cut-Out (TCO) - (part number 279769 includes the Hi-Limit Thermostat).
    *If either the TCO or Hi-Limit Thermostat is determined to be defective it is recommended that you replace BOTH parts at the same time. That's why they are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
    The heating element is located inside the heater box. The TCO is located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit thermostat will be located adjacent to the heating element terminals.
    Searspartdirect.com has an excellent exploded view diagram of all these components. Just type in your model number and locate the following under the "bulkhead" section:
    TCO/Hi-Limit Thermostat - Item 1
    Heating Element - Item 14
    Hi-Limit Thermostat (by itself) - Item 34
    The reason I mention all these components is because if you have not confirmed the heating element to be defective, you may actually have a blown TCO or Hi-Limit Thermostat. Its easy to assume a bad heating element if the dryer fails to heat, but it may or may not be the cause. Just some additional things to consider, that's all. These components cost less than a heating element too. If you have determined the heating element is bad, then continue with the following:
    4. Disconnect the leads to the heating element and locate the screws that hold the heater box in place.
    5. Locate the screws on the outside of the heater box that hold the element in place. You may also have to remove the TCO and Hi-Limit Thermostat.
    6. Once the screws are removed, the heating element will slide out of the heater box. The element fits tight and it may require a little effort.
    7. Once the defective element is removed, install the new one by sliding it inside the heater box. Make sure you align the screws holes.
    8. Reinstall the remaining components and reinstall the heater box.
    The rest is self-explanatory.
    NOTE: A good heating element will read approximately 9 to 13 ohms. Make sure you disconnect any leads before taking any measurements to ensure accuracy of your readings.
    The following link explains a good portion of what I've already explained to you, but it may help as well:
    http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
    Pay particular attention the section that discusses proper air flow. The majority of all dryer heat related problems are attributed to poorly installed, kinked, clogged or crushed exhaust vent ducting. If you haven't thoroughly inspected the dryer and ducting recently, now may be a good time to do so. Otherwise, any components you replace will fail prematurely. Not to mention, a clogged dryer is also a fire hazard.
    If you have any questions, please let me know. I hope this information is helpful to you.
    Oct 20, 2009 | Dryers
    Need heating element for oven of 1950's Frigidaire by GM stove
    Fixya is unable to identify parts sources.
    Jan 23, 2018 | Ovens
    Rowenta DX-8800 will not heat. Location of heating element?
    The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
    Dec 30, 2008 | Rowenta DX-8800 Iron
    Kenmore 63942 Dryer Logo
    Top Kenmore Dryers Experts
    Dan Webster
    Dan Webster
    Sal De
    Tim Whalen
    Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
