Question about Bulova Watch
Setting time, date, month and day for diesel model dz7087
I am havig an immense amount of difficulty with the dz7087 from diesel. I can't set the time, month, day on this watch. The manual it came with does not include this model of watch. lease advise if you can be of help.
Thanks,
Kim
  • 2,334 Answers
As there is no possibilities to download manual for your watch, you have to contact Diesel yourself by email or by phone. Here is the contact info:
If you need help with product information, ordering assistance, or returns information you can contact us via one of these three options:
Diesel Time Frames Customer Service
2280 N. Greenville Ave.
Richardson, TX 75082
TEL: 800-699-2556
customerservice@dieseltimeframes.com
Don't forget to rate, please.
Posted on Jan 14, 2009
How do i set the date on the diesel dz-1216
two possible methods
1/ pull crown out to first stop rotate clockwise for date and anti clock wise for day.
2/ pull crown out fully to start moving hands rotate hands through twelve O'clock twice for each day to move when at the correct day set the time then pull crown out to first stop to adjust the date, push crown in fully when done.
Mar 03, 2015 | Diesel Strap DZ1216 WW Watch for Men
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
Pulsar watch, how do you set the day of the week and month?
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Jul 08, 2010 | Seiko Watches
Can you set the time going counter clockwise on a watch
yes, you can set the time counter-clockwise on a watch. The only difficulty that may arise from this is making sure the date window (if you have one) syncs up; but a 1 hr change for time change will not make a difference. For best results start setting with your day window reading 1 day before the current day and begin turning clockwise. Right when the day/date changes the watch is reading 12am(midnight); set accordingly.
Nov 03, 2009 | Bulova Watch
Instruction Manual for DZ-7087
hey..i found out how to set the time for the model: diesel dz7087..
all u have to do is press and hold the light button..the when it starts ticking press the mode button repeatedly to set the time,date,etc...when u finished setting everything press the light button and everything will be set..
ciao ciao
Sep 09, 2008 | Diesel Audio Diesel Watch
How to set time on Diesel DZ 7071 Watch
Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
Dec 20, 2007 | Watches
Date and month
There are three positions when you unscrew the crown stem. One does the day, one does the date and one does the time. You can also advance the date by rotating the crown stem and advance the time for 24 hours, as if a day passed. That takes a lot longer.
Sep 15, 2007 | Rolex Daytona 116520 Wrist Watch
Bulova Watch Logo
279 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
