Question about Canon CanoScan LiDE 70 Flatbed Scanner
Data transer error "Twain source code 2,155,0" Will not scan
I tried to re-install - but it still will not scan. Any suggestions?
SOURCE: Error message
Hi toolpusher
Try going to CanoScan Toolbox > Settings and reset the 'defaults' button at bottom... this will restore factory settings and hopefully fix your problem... The other error message you can expect to get is "unable to scan - insufficent memory, check your **** space' (or something similar)... same fix works for both! ...Have had both messages on mine, sounds like a semi-regular conflict on some sort, but seems to be easily fixed. Good luck :-)
Posted on Sep 30, 2008
  • 111 Answers
SOURCE: canon scanner
TWAIN is the type of scanner driver that is used for this scanner. It is probably the most common type of scanning driver.
Did you install Toolbox? Not sure? Assuming this is Windows, click Start, All Programs, Canon. Look for open CanoScan Toolbox (4.9 I think). Once this is open, click the 'Settings' button. There should be a drop-down menu for 'Select Scanner'. Make sure this shows the CanoScan LiDE 25. If that scanner is not listed, then the scanner driver is not being seen or may not be installed.
Once it has been verified that the LiDE 25 is selected, click OK. Next, click the 'Save' button. Check the box for 'Display the Scanner Driver'. Now click the 'Scan' button at the bottom.
The next window that pops up should be ScanGear. If this happens, then everything is installed and the scanner is being detected properly. Attempt to scan or preview.
If there was a particular application you were trying to use and you are still having issues with it, please give those details.
Posted on May 19, 2008
Scott Ellin
  • 558 Answers
SOURCE: unable to scan
Hi Franklin_mus,
Thanks for your posting in FixYa.
It seems to be the problem of the Drivers and incomplete installation. Please uninstall the Scanner and do a complete installation step by step.
Let me know if you need any further assistance from me. Have a Nice day.
Regards
ELLIN
Posted on Sep 20, 2008
  • 1335 Answers
SOURCE: how do i install TWAIN drive
Go to
http://www.usa.canon.com/consumer/controller?act=ConsumerHomePageAct
put in your model number and you will find the correct driver for your scanner.
Please make sure to rate this solution. Thanks.
Posted on Jun 09, 2009
SOURCE: TWAIN Driver Error
If the windows image acquisition service is running, stop/disable it and see if this helps with the apparent concurrency problem.
Posted on Apr 16, 2010
I have HP Officejet J3680 All in one I wanted to scan a document but it is saying there is not option..
canning functionality from the LJ3380 and CLJ2840 series All-in-One devices may not function until the correct Twain Data Source is selected by the user. This can be done by attempting to scan from the foundation scan executable "hppscan2.exe ".
  • For the LJ3380 series this is located in C:\Program Files\Hewlett-Packard\LJ3015_LJ3020_LJ3030_LJ3380->hppscan2.exe
  • For the CLJ2840 this is found in C:\Program Files\HP\Digital Imaging\bin->hppscan2.exe
When the "hppscan2.exe " is launched from this location where it resides, a dialog box will open with a "Select Source " box listing the installed Twain scanning devices available. If this box is not seen, then there is only one Twain device installed. In some instances user input is needed to chose the "correct" Twain data source for scanning to be successful from the LJ3380 and CLJ2840 series devices. If the incorrect Twain data source is selected- an error "Cannot initialize device " will be seen.
Oct 27, 2010 | HP J3680 Officejet All In One Printer
Error message cannot find twain source and toolbox
Have you tried deleting the scanner from add/remove hardware under control panel? If not, try disconnecting it from the computer, then try deleting it, then retry the install one more time.
Aug 19, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Stopped at start-up after months of no problems
Please trash the twain driver completely.
- Trash epson scan and epson scanner monitor from applications.
- Go to hd. Go to library, then application support. Trash epson scanner module.
- Go back to library. Click on image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on your computer name. Click on Library. Click on preferences. Click on the epson folder. Trash epson scan.
- Empty the trash and restart your mac.
Log on to epson.com. Install the epson11926.dmg.
Apr 28, 2009 | Epson Expression 1640XL Flatbed Scanner
EPSON STYLUS CX4800
You need to download a "Twain Driver and Epson Scan Utility" from
the Epson Website.
But before you start downloading the Twain Driver we need to delete
the previously installed driver in your computer.
1.) Click and open the MAC or Apple Hard drive / Application and trash Epson Scan and Epson Scanner Monitor ( drag it to your trash )
2.) MAC hard drive / Library / Image Capture / Twain Data Source., we need to trash ( *.ds file )
3.) MAC hard drive / Library / Application Support., trash the Epson Scanner Module
4.) Disconnect the connection ( USB ) between the printer and your MAC.
5. ) Empty your Trash bin and restart your MAC
After the restart we can now download and install the Twain driver to your MAC.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58606&prodoid=56291067&infoType=Downloads&platform=Macintosh
After the installation try to launch Epson Scan under Application
Feb 10, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus DX4450 scan macintosh problem
Trash and re-install the drivers.
To uninstall the drivers:
- trash epson scan and epson scanner monitor from applications.
- go to library, then application support, then trash epson scanner module.
- go to library, then image capture, then trash twain data sources.
- go to the harddrive. Then to users, then click on the name of your computer. Then click on library, then preferences, then epson, then trash epson scan.
Then log on to epson.com and get the compatible driver for 10.5.6. Install it on your computer.
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Unable to "communicate with TWAIN data source." ??
This may happen because of overload to memory. If all are ok and still this error comes up means, the twain driver takes more time to load. wait for some seconds and then click scan, it will go.
Try to clean the hard disk and defrag the drive.
Jun 02, 2017 | HP PSC 1315 All-In-One InkJet Printer
Twain Complient
twain data transfetr error help please
Oct 20, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
I have a HP photosmart C6180 all-in-one and I am trying to scan a picture onto the computer but every time I go to the scan menu it says Error: Sorry, scanner could not be initialized. (Scanner not found.)
I get this every now and then, usually because, during a scan, I abort for some reason--reset the computer, force-quit, whatever.  The printer driver, I think, leaves some breadcrumbs that it can't recover from when it runs again.
Anyway, I reset the printing system and install the latest HP driver.  If that doesn't work, I delete the HP folder in the Applications folder; then remove whatever files I can find in the /Library folder such as Application Support/Hewlett-Packard, Application Support/HP, any HP file in Preferences, Image Capture/TWAIN Data Sources/HPScanPro.ds.
Then reinstall the driver and things work fine.  I'm thinking this last item, the HPScanPro.ds in the TWAIN folder might be the culprit but I haven't tried just remove it alone--after I remove everything things work so I can't "try it again"...and don't want to!  =)
Anyway, I've had success with this method.  Good luck!
Jul 13, 2008 | Office Equipment & Supplies
Scanner will not connect to computer
'Twain' only means 'Technology without an important name', as this is refering to your printer/scanner, i would suggest that you disconnect the printer and remove any driver from Add/Remove programmes. Re-install printer software/driver and re connect printer when prompted and if possible in a different usb port, if that's how it's connected. If the problem persists and the pc is unable to communicate with the printer the fault will lie with the hardware. Hope it's only a driver glitch.
Nov 27, 2006 | HP PSC 1510 All-In-One InkJet Printer
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
1,087 people viewed this question
old marine
old marine
