Question about Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range
Range goes into lock out mode for no reason
In Sept. 2006 I had a new GS563LXSS gas range installed. Sometimes during heavy rain and wind storms the range would automacally go into a lock out mode. The computer panel was replaced, electricians checked the outlets, plumbers checked the gas line, appliance people from 3 different appliance centers looked at it, customer and technical service at Whirlpool were cotacted. Nobody ever heard of this happening and had no solution. The stove was replaced with the same model # in Feb. 2007. The same thing has happened twice. The electrician put the range and microwave on separate circuit breaker, the power compny said they checked the transformer.The range was attached to a generator to make sure the problem was not coming from my electial hook up. Once during heavy rain the new range went into lockout and when it was attached to the generator when resetting th e clock it went into lock out mode. I can get it out of this mode by holding the button marked "lock out". Why, do you think, this is happening?
  • mekolbeck Nov 02, 2008
    GOES INLOCK MODE FOR NO REASON AND AT NO PARTICULAR TIME AS FAR AS I CAN TELL.
  • velozfrankli Nov 05, 2008
    I have the same problem when the electricity go off the gas stop.
I posted a similar problem earlier today but never saw it come up. Anyway I found the problem for me. My problem was a "LOC" display came up when I plugged the stove in after bringing it home (bought used off craigs list). This made the stove top inoperable, no gas supply.
SOLUTION:
There is a Cooktop Lockout as part of the night light switch which you hold down for 3 seconds to activate or deactivate. This is not the same as the Control Lockout which is next to the switch I am describing. Anyway doing this will make the "LOC" display go away and you will hear the gas valve activate or deactivate respectively.
Posted on Oct 16, 2008
  • 76 Answers
This is a new "safety feature" that Whirlpool intalled. If there is even a momentary interuption or fluctution of power your range will go into lock out.
Posted on Jul 01, 2007
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Range goes into lock out mode
I have experienced this with a Maytag model before. What I was told by the technical assistance folks, is that fluctuations in power coming from the line voltage being fed into the home, electrical storms, or even ham radio (high power RF) operating in the area, can cause some electronics to appear to have problems when they don't. The theory is that these circuit boards are so sensitive that even the slightest noise or interference on the line voltage coming in can cause the board to go into a lock out mode. I was able to clear the problem I had by resetting the computer. There is an actual procedure for this if you haven't figured that out already. If you haven't figured out how to reset the unit, you may need to call the technical support department for your model to see if they can provide you with better answers. I hope this sheds some light on this problem for you.
Posted on Jul 09, 2007
I Cooktop locks when power goes out.
Hi, unfortunately your range needs power to energize a solenoid which allows gas to flow to the cook top. It would seem that you may have inadvertently got the wrong model. This feature is only handy when there is a safety need to limit access to the burners. Theoretically,  the solenoid could be removed and the gas would then work with no power but you may be better off selling the range and buying another one. Best of luck.
Jan 27, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
I need to know how much it would cost to purchase an Oven Control for my Whirlpool Kitchen Range, Model# GS563LXSS, SN RU0127557 During hurrican Ike their was a power surge when our electricity came back...
Most controlboards can't handel a power surge more than 125V and is a reasonable expanation.
Your model number is missing a number at the end and if your model # is GS563LXSS0 or GS563LXSS1 then the Main Control part # is a W10116542
Jan 09, 2010 | Whirlpool GS563LXSS - stainless Steel Gas...
E1 -F5- .. Locked - displays after cleaning the
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Dec 21, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Oven goes in lock mode.
unfortunately it sounds like you need a new board
Dec 31, 2008 | Magic Chef 31000 Gas Kitchen Range
Whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
May 15, 2008 | Whirlpool GS563LXSS - stainless Steel Gas...
New gas grill fell in storm
Sounds like either a defective valve or that the components to it have misaligned. Inspect all valves and other parts. If some look different from the majority, replace them. Do not use the unit until you do.
Feb 19, 2008 | Grilling
Wind comes through island hood
Thee is supposed to be a damper in the vent pipe were it connects to the hood. maybe its missing or stuck.
Nov 02, 2007 | Kitchen Ranges
Jun 14, 2007 | Whirlpool GS563LXSS - stainless Steel Gas...
Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range Logo
594 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
