Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
I am not sure if I am setting the clean mode correctly.
I am trying to claen my self clean Kenmore oven.How long does it take for the cleaning to end?
    President:
  • 1,214 Answers
Most self cleaning ovens that I have been around clean in 1-1/2 to 2 hours. See you Owner Manual to be sure.
If you can't find your Owner Manual, let me know, I'll see what I can dig up.
Posted on Jan 14, 2009
How do I clean Kenmore electric range model; 36393091300 .No manual for this self cleaning range.
Hi,Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Where can i get cleaning instructions for a Kenmore model 4652591 self cleaning oven?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
Mar 23, 2011 | Kenmore Ovens
Ask a question yesterday did not get an answer .i will ask again kenmore self cleaning oven tried to clean pressed button door locked .after ten minutes oven did not heat up to clean did i miss a step that...
heatman101
Nov 09, 2010 | Kenmore Ovens
What temperature do I need to set my oven to for Self Cleaning?
heatman101
Sep 18, 2010 | Kenmore Ovens
Frigidaire wall oven single, FEB27S5DS,Tried to set self clean, oven locked, beeped,and then flashed F93. I held in the "end" button for three seconds to no avail. I turned off the breaker for 30 min...
heatman101
Sep 16, 2010 | Ovens
How do I claen it? I have no directions with this oven Im not sure what all the funcions are and what the symbols are on it. Is there an insruction book?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 08, 2010 | Ovens
When i try to bake in my kenmore gas oven it gos to self cleaning mode and will not let me use the oven
Some how somebody pressed self clean and didn't let it finish. Press self clean again, let it run thru' and then U wil B A O K.
Aug 01, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
There is an E1 F5 code appearing when I set the self cleaning button. I need your assitance. I have a Kenmore electrice self cleaning stove and it was in the house when I bought it six years ago. .
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Jul 24, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven door will not unlock
Hello,, Some times this will happen after a self clean cycle if the timer did not finish the entire clean. Try to set the clock to start the self clean again then simply end the self clean. This should unlock the door. If the door remains locked. You may check the oven for an error code, or the door latch itself may need to be replaced. One other possible would be to turn off the power to the oven and try to let the oven control reset. leave the power off for about 15 minutes then turn the power back on. That will sometime work aswell. Good luck and feel free to call me if you need more help.
MIchael Anderson
Anderson Appliance
(865)945-3808
Feb 10, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
130 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
