Question about Coleman Powermate 27 Gallon Air Compressor
Need replacement brushes for Coleman Air Comp L0552709
Can you tell me where I can find the motor brushes for the above Coleman AC?
    Problem Solver:
  • 5 Answers
You can try at mastertoolrepair.com they have parts just have to see if your model is in there system
Posted on Jan 26, 2009
Coleman mach ac blower stopped
bad motor windings.replace the motor
May 07, 2012 | Coleman Mach III Air Conditioner
I need new brushes for Powermate Air Compressor motor. Where can I purchase them or do I need to have a Technician install? Model #CL0551109 Thank You J.L. Brooks
Brushes are not listed as a replacement part for your compressor. Not to worry because universal brushes are available at tool repair shops, hardware stores and ebay. Measure your brush and order same size or slightly larger and sand to fit. Dont worry too much about the length of brush as they can be shorter than factory and still work fine (just longer than worn brushes). Some motors have a spring pushing brush onto armature and others utilize the spring attached to brush to make contact. You can cut off wire from back of brush if needed, however if your motor needs brushes with spring attached, find close match and solder your old contact and spring to new brush. Also check for other problems because brushes should last the life of motor on your unit. Good luck
Aug 17, 2010 | Coleman Powermate 27 Gallon Air Compressor
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
HI; How do i change the brushes in an electric
Motors with carbon brush can be detected due to the two brush access at two opposite sides. Open this up,
and you can already change the carbon brush.
However, if your motor doesn't brush access, the probability is your motor is a capacitor motor. Replacing
the capacitors will restore your motor proper speed.
Oct 27, 2009 | Coleman Powermate 4 Gallon Air Compressor
AC unit wong start unless I spin the blower
you have 2 windings that are in you motor,One winding is the start winding It give the motor its initial boost that gets the fan spinning.The other winding is the run winding and it takes over and keeps the fan running.So it sounds like the motor is bad because the start winding is not giving the boost it needs to start. good luck--Nate
Jul 15, 2009 | Coleman Mach III Air Conditioner
Coleman AC compreser work but fan dont
If the selector switch is broken, you need to replace that first. This will cause the fan not to come on if there is an open in it. After replacing the switch, if you still have to fan operation, it is possible that you have a bad fan capacitor, part# 1499-5461, or a bad fan motor, part# 14683099. Replace the capacitor first before spending the money on a motor. An easy way to check is to see if you can start the fan motor by hand while turning it on a the selector switch. If the motor starts this way, replace the capacitor.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic 57915531 Air Conditioner
Sparking brushes
try blowing out motor i have used a armature cleaner like acetone while motor is unplugged or just replace brushes
Jun 26, 2009 | Coleman Powermate 60 Gallon Air Compressor
Need fan motor part # for Coleman RV AC mod # 8534B876 2 speed
The Motor that you are looking for is part #14683109. This is the coleman part number and you should be able to contact your local RV Repair facility and give them this number and get the motor. Hope this helped.
Jeff
Jun 09, 2009 | Coleman Mach III Air Conditioner
Replaced blower motor on coleman ac
You MUST always replace a capacitor when you replace a capacitor start/run device.
Replace the cap.
May 24, 2009 | Coleman Heating & Cooling
Coleman 5000 generater-no AC output
have you conected the brushes on the right way? the leads are + and -.
you can run it up and use a 12v battery and connect it to the brushes correct polarity, with the othe LEADS removed and taped can shock you and chect the out put it it around 100 120v chech the AVR or brush polarity.
If yours dont have brushes it will have a capasitor that is prob out of spec.
Jan 10, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 27 Gallon Air Compressor Logo
314 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
