Question about Toshiba 46H84 46" Rear Projection HDTV-Ready Television
There are wigley lines top to bottom inthe video in tunner and video in
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
The model listed here has a HYPER board that processes all signal in the set from all inputs and usually in these sets it will begin with the problem being there when first turned on and after several minutes it goes away--gradually it takes longer and longer until it will not go away----Is this what happened to you?
Posted on Dec 17, 2012
  • Philip Burns Dec 24, 2012
    Thanks for the reply I take it I need to find a nother board I known which one you mean but the set is to old Thanks Phil
  • Robert Stigliano Feb 19, 2013
    Yes this is what's happening. It's getting worse but it does go away
SOURCE:
We dont have an ice machine but keep getting water turning to ice inthe drip pan is something going on
Bottom freezer, top freezer or side freezer?
In any case it is probably due to the defrost cycle (or,and) a plugged drain tube.
Attached is a youtube video showing how the defroster works.
Refrigerator Repair Not Cooling Defrost System
https://www.youtube.com/watch?v=TnRKj7_BtNw
Sep 03, 2014 | Whirlpool Refrigerators
When i install tvr for tv tunner , the computer need multi video controller, what must i do? please help me
Download A multi video driver for that tv tunner.. Look at the manufacture website see if they have one for you or search google.com for a driver to download and install and you should be fine after.
Dec 21, 2010 | Computers & Internet
I have a scott tv...2 days ago an electrical storm hit the cable lines....i had to replace my modem, router and call cable company to repair lines...tv works fine on all other connections, ie; laptop, dvd,...
TUNNER BAD, YOU NEED TO CHANGE THE MAIN BOARD OR CHANGE THE TUNNER WITH AN OLD USED BOARD. MAYBE IF YOU OPEN THE TUNNER FIND A OPEN LINE NEAR COAXIAL CONNECTOR.
Apr 20, 2010 | Scott LCT37SHA TV
I want to copy video footage onto PC/Mac from Sonday Handycam
You will need a standard video/audio rca cable (has a video out connector and audio on left side of lens), and a tv tunner (check that it has the rca in) that you can get as either usb (better double check if you have a usb 2 port on computer as it might be needed for capturing the video) or as a pci card.
Ussually the tunner would have a software to "capture" the video to the computer. And you would need to put your cam on play mode and start "capturing" and stop both the software and cam when the video footage ends.
I recommend corel studio 12, as it is very easy to use. Basically with corel no know-how required. Simple choices. Another great sofware is dvdsanta.
This would be for the pc.
Best wishes!!
A mannual for the cammera can be downloaded from: http://www.nodevice.com/user_manual/sony/camcorders1/ccd-trv16e.html on the bottom of the page you need to type in the letters on the square and press download.
Apr 15, 2010 | Sony Video Cameras
A black line inth midel of plasma
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Nov 19, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
NO SOUND IN RECORDING THRU pci tV TUNNER
open your tv viewer and go to factory settings and go to video settings or something like that and turn your and set the mixer device from xxx output to xxx input and select the recording to line in
Jun 07, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
KV-32HS20
hi there, you do have a tunner problem, the little metal box is the tunner which is connected to your arial anttena or cable line. try to toch the ic near the tunner and feel if is it hot, you may be have a defective ic parts. check some parts at tunner section. ty
Dec 26, 2007 | Sony KV-32HS20 32" TV
Ther is a test you could do is you had the proper equipment, and that would be to inject a know good RF signal into the tunner F connector and chech tha point where the RF/IF is converted to audio and video, to determine if the proble is a bad tuner or not. The equipment is a VA62A Universal Video Analyzer. Its a great piece of equipment for this type of work. another thing you can do is get an RF Modulator from Radio shack and input a video and audio signal in to it and set it to channel 3 and connect the F connector to the TVs F connector. The set the TV to channel 3 you should see the picture and hear sound in channel 3. The VA62A is best because you can set it to emulate all of your channels from 1-87 standard TV and Cable TV. In any event a test needs to be run to see if the tunner is at fault.
Aug 23, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Intermitent colour and black & white picture when recording through Line 3
your vcr tunner is faulty take it to a tech and have him change the tunner.or probably you are connecting the wires wrong.
Feb 17, 2007 | Sony SLV-SE840 VHS VCR
Toshiba 46H84 46" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
