Question about Brother MFC-8860DN Printer
I have a Brother 8860DN that won't work on my Cisco Catalyst switch. I get no link light when I connect it to any switch port. However, I can hook up a simple D-Link switch to the Cisco and plug the Brother in and it works fine. I'm assuming it is an auto negotiate (speed, duplex, etc.) setting, but I can't seem to find where to set this on the Brother web interface. Any ideas?
5 Suggested Answers
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
SOURCE: Fuser replacement on Brother MFC 8860DN
Yes I did it myself, however I am savvy with most hardware, I wouldnt suggest it for the novice. It cost around $NZ245 for the fusing unit, which from doing a quick search online is about the same in most countries.
Posted on Sep 03, 2008
  • 56 Answers
SOURCE: Tech manuel for 8860dn
Just manuals sells them. Like $12 us
That should take you right to the page with the manuals.
Good Luck!
Posted on Jan 15, 2009
  • 46 Answers
SOURCE: looking for corona wife for brother 8860dn MFD.
Try to get some corona wire stock which was quite common back in the day and install it in your drum.
Posted on Aug 28, 2009
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
Aug 15, 2014 | Computers & Internet
Cisco Catalyst 2960-S VS 2960-X Series Switches?
2960-X is manual configurable and 2960-S is smart dont need to configure.
Apr 10, 2014 | Computers & Internet
Due to the length of the solution I have provided you with a link to the Cisco site on how to reset catalyst switches.
It is not a simple process and you need to read the instructions carefully.
Dec 15, 2010 | Compaq Cisco Catalyst 296024S switch 24...
50 port lan switch specification
It should like you would like to move away from a chassis switch with blades? You have a number of options, depending on whether you also require PoE or stackability, and specifically what optical connections you require. There are many, many options, depending on the specifics of your need. The Cisco Catalyst 3750G-48TS is one likely option, and is stackable to provide a redundantly linked "core" with a shared backplane. See Cisco's page for other options within this product line.
If you require additional info, or help with the project, please feel free to contact me.
Jan 12, 2010 | Cisco Catalyst 4006 Chassis ( 4006)
I have such a problem, i am trying to connect a dlink switch with a cisco 2900 switch and ports do not synchronize, while as with another cisco 2900 it syncronizes
You should confirm that all speed/duplex settings match on both sides of the link. Also ensure that there are not VLANs set on the ports to which you are connecting, as that will also prevent communication if misconfigured. In addition, if you do a "show log" on the cisco switch console, it may give you more insight into what's happening as the specific log entries will be relevant.
Jan 05, 2010 | Cisco Catalyst 2900 XL Networking Switch
Lucent Cajun not talking to cisco catalyst
Not sure what Cat switches you have, but the cajun switch must use the same trunking encapsulation.  Older catalyst switches use ISL trunking which only work with Cisco switches.  Make the port between the lucent and cisco dot1q encapsulation on the cisco trunk port.  Also turn on debugging on the cisco and see what messages are generated.
Apr 27, 2009 | Lucent Cajun P220G Networking Switch
Brother 8860DN won't work on Cisco switch
Go to the menu settings on the machine itself. Cycle through the options until you find the network settings. Make sure the device has network on and set the connection to DHCP on. save or back out and then restart the machine. It could also be a problem with your Cisco switch and the IP address ranges that the printer and switch have. You may need to specify an address in the printer settings to allow access through the Cisco switch.
Nov 22, 2017 | Brother MFC-8860DN Printer
Can't get internet connection
Check the following
If your link light on the swich port turn green when you connect the Airport to the switch then the connectivity is okey. if not then try connecting the airport with a crossover cable.
If the link is on, then I need the following information. please draw the connectivity and upload and the switch configuration.
Nov 26, 2007 | Cisco Catalyst 3560-24PS Switch
Brother MFC-8860DN Printer Logo
35 people viewed this question
James Cagle
James Cagle
Jim Keysor
