Question about Whirlpool Ultimate Care II GSQ9669L Top Load Washer
Push on lid to get the washer to work.
How can I fix the "lid closed" lever? I was able to put a heavy bottle on the lid and it would work, then 2 bottles, etc. Now I have to push on the lid with my body or push the "lever" with my finger for it to work. How can I fix this so I can go and do other things while I get laundry done? Thank you in advance!!
  • 1 more comment
  • Jen Driezen Jun 15, 2007
    I'm getting the part today and would love it if you could give me a step-by-step. Thank you!
  • Jen Driezen Jul 09, 2007
    The washer is working great again! Thanks for offering to help but it turned out to be a pretty simple job. I got the part and it's done! Thanks again!
  • cdawdy Mar 13, 2009
    The tub of my washer fills with water and then never starts the agitation cycle. If I lift the lid several inches and then drop it, it starts working again. I suspect it is the lid switch, but I cannot find where it is in the machine. Other sites link to MSN groups which is now closed.
    Do you have instructions on how to replace the switch?
  • 5,911 Answers
The item you are talking about is called the "lid switch". It is not normal to have to place anything on top of the switch in order for it to work properly. In fact, you may have caused more damage than good. The switch has to be replaced and runs about $35 US. Don't know what it would cost up north. If you decide to replace yourself, let me know and I can give you step-by-step tips.
Posted on Jun 15, 2007
  • Jeff Rockwell
    Jeff Rockwell Jul 08, 2007
    Do you still need assistance on replacing the switch or am I too late?
SOURCE:
I HAVE A TOP LOADER WHIRLPOOL LXR7144EQ1. i HAVE TO PUSH DOWN ON THE LID AFTER CLOSING IT OR HAVE SOMETHING HEAVY ON TOP FOR IT TO CONTINUE TO WASH. WHATS THE PROBLEM?
It sounds like the lid switch, which senses when the lid is closed, needs adjusting. You will need to remove the top of the machine, locate the switch and move it closer to the lid actuator.
Jul 07, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
How to reset toner on Ricoh Aficio 180
If you want to reset the toner bottle, open the front cover, lift up on the green toner handle, push the lever in to slide out the toner hopper, pull out the toner bottle, give it 1 or 2 gentle shakes, and put it back in the hopper. Then push the hopper closed until it snaps into place, push the handle back down, and close the front door.
May 25, 2010 | Ricoh Aficio 180 Laser Printer
Trunk latch on 2002 Civic EX 4-Door won't close
trunk latch cable probably needs to be replaced
Jul 06, 2009 | 2002 Honda Civic
Error Epson RX 595- Close the Scanner Unit
I just had the same problem. I figured that there must be a lever that gets pushed in when the lid closes and sure enough there's a square hole in the vent area (look in the area below the serial number) and in that is a small lever is that gets pushed down by the piece that's attached to the lid. For some reason, it's not pushing it down far enough or the lever has bent and it doesn't connect. My only solution (for now) was to jam a pencil into the lever to push it down all the way and sure enough, it worked. I'm sure there's a better, more permanent (and more attractive) way to repair this, but for now, it works and I need to print out 60 copies of an event program for tomorrow night! Good luck!
Jan 24, 2009 | Epson RX595 Photo All-In-One Printer
Whirlpool cabrio top loader,always having to "reset" 2 times 1 cy
Hi Curtis: File a class-action suit against the Whirlpool company. There is something wrong with the electronic module that tells the washer to shut down during the rinse cycle.
If you pause, lift the lid, pour in about 3 gallons of water into the tub, close the lid, push start, the washer should continue without having to wear out your fingers pushing the buttons. The buttons will eventually be pushed down into the control panel and you will have to use a pencil to reach them.
Also helps to have a nice cool bottle of regular beer (not the light stuff) before you start the load, the washing duty will work out much smoother. Good Luck.
Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer stops for no reason.
i would be concerned teh the door/lid switch is not being activated, or is loosing contact withthe swtch mid wash causing unit to shut off. unitll the lid is lifted and closed to make better contact.. tyhe activator for the lid switch is actually the underside of the lefthand lid hinge. so if your able toreah under the lid while open you feel the metal lever, as you push and pull hte lid youll feel the lever move as well. with a hollow shafted screwdriver/1/4 nutdriver. place the driver over the metallever andslightly bend it toward the rear of the uni, so it makes better contact with the switch mounted tothe underside of the main top assembly
Nov 20, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
For weeks now I've had to slam the lid on my washer to get it to work. Now nothing! The same thing happened to my dryer...close the lid and nothing. It wasn't even a year old and someone had to come out...
ck lid screws especially on newer models on these the lid switch is located left rear corner just behind lid hinge if switch is on right side close lid slowly and listen for click if none heard try pressing down on lid at switch location if washer starts replace switch if switch lever broke change switch..on other type switch lower lid slowly and listen for click if none heard and hinge screws ok raise lid and push lid hinge toward back slightly and try again still no click raise console switch is on left and just snaps in place
Sep 04, 2008 | Whirlpool Washing Machines
WASHER FILLS BUT THEN WON'T START. WILL LIFT THE LIFT AND CLOSE SEVERAL TIMES AND THEN WILL START. NOW DOESN'T START AT ALL. IS THIS THE SWITCH ON THE DOOR, SHOWING IT ISN'T CLOSED SO IT WON'T START?
must be a whirpool or kenmore shut lid try pressing down on left rear corner be sure lid hinge screws are tight then raise lid on left corner under top out of sight you will feel small lever push toward back of washer slightly and then try again also if lid center has popped down push up slightly in center till lid pops back up sen it happen once where washer would not spin
Jun 17, 2008 | Washing Machines
Washer will not complete rinse cycle and will stop.
it is probably the piece that your lid pushes down to let the washer know that it is closed try hitting the lid realy hard.It happened to me i have to do it every time
Feb 11, 2008 | Estate TAWS800JQ Top Load Washer
Whirlpool Ultimate Care II GSQ9669L Top Load Washer Logo
187 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
