Question about RCA P52926 52" Rear Projection Television
Tv wont come on at all
This is the third television I have had go out in my living room. All 3 worked at other locations just fine and when they were placed in the living room within 1 week they were "out" no power at all. I was told the repair would be $400. Is this something I can find on the internet and do I truly need an outside professional to fix?
  • Josh Crager
    Josh Crager May 11, 2010
    what kind of tv is it?  - also you may look into an un-interuptable power supply / sureg protector combination - these are mainly used on computers, but you cannot go wrong using one on your tv!
  • 548 Answers
Run an extension cord from another room to see if the tv still works. It sounds like faulty wiring in the living room that needs to be checked. Also, check for a tripped circuit breaker for that area of the house. Can't tell you about the repair but, you will save yourself some time by checking these things out first.
Posted on Jan 14, 2009
We had a thunder storm on Thursday lightning struck the dish and both t.v.s went off. my wife called dish they came and change everything,know mt t.v in the living room works has volume my t.v. in the bed...
. Make sure that you don't have mute on, and make sure your TV speakers are turn on. Go to menu and see if there is a way to turn your internal speakers on. If you can't fine anything , then your audio processor could be locked up, and if you unplug your TV for 30 MIN. it will reset the processor back to normal. Good luck and have a nice Day.
Oct 16, 2010 | Protron PLTV-37 37 in. LCD Television
We move the tv from living room to bed room and we have to change the chanel from 3 to 60 to get the tv to work on dish network, we try to change from 3 to 60 we try evereything whit no result, we call...
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
Sep 04, 2010 | Televison & Video
I have sound but no picture from all my AV inputs on LCD TV. It was working fine then when I switched sources from sky to xbox they stopped working. All connections are fine
Ur LCD inverter board is dead.Replaced this board will get the piccture back.It a long board.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Brought new tv for bedroom freeview inc..set up
If you have got a good aerial, the high gain type- see image, it should run all the TV's you say. Make certain you have decent cable coming off the aerial (the stuff they use for satalite dishes). Then buy some high quality splitters, to feed the TV's. Don't split the cable outdoors!
Jan 25, 2010 | Televison & Video
Moving tv to another cable outlet
I f you have cable at the new location follow it back to a splitter. Remove the one you used to use and screw in the one you want to use. They should all terminate at the same location.
Jan 17, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
RCA P52926 52" Rear Projection Television Logo
51 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
