Question about HP OfficeJet k60 All-In-One InkJet Printer
Repeat cartridge jams
I'm not able to print at all, both cartridges are full of ink, the printer keeps saying replace black cartridge or cartridge jam
Not really a solution but I went through this with an HP ink jet printer last year. HP basically said there was no solution. Had to toss the printer. HP's just do not hold up in my opinion.
Posted on Jan 15, 2009
My printer isnt feeding paper in straight and it keeps on jamming and saying that there isnt any paper.. is there anything i can do to esay fix it???
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Oct 25, 2010 | Office Equipment & Supplies
Had paper jam. Followed instructions to release
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | HP Photosmart C6280 Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Paper Jam
try these steps
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Feb 14, 2009 | Dell 810 All-In-One InkJet Printer
Full black ink cartridge - but says there is no black ink
To run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
Wicking the cartridges and cleaning the contacts on the back of the cartridge should be performed if the nozzle clean was performed and the quality was not satisfactory.
Wicking the Cartridge
  1. Ensure the printer is powered on.
  2. Lift the scanner unit.
  3. Open the cartridge latches and remove the cartridges from the carrier
  4. Take a clean, damp cloth and wipe the nozzle of the print cartridge from front to back
Cleaning the Contacts
  1. Turn the cartridge so that you are looking at the contacts on the back side of the cartridge
  2. Using a clean dry cloth, wipe the contacts in the direction, so that no dust or other contaminants are visible.
  3. Clean the contact inside the printer with the dry cloth used to clean the cartridge contacts.
  4. Replace the cartridges in the carrier and close the scanner unit.
  5. Print the document again.
  6. If the print quality does not improve, repeat the steps for cleaning the nozzles and contacts up to two more times as needed.
Verify the Ink Cartridges Are Installed in the Proper Slot
  1. Remove the ink cartridges from the printer.
  2. Read the label on the side of both cartridges to identify which is color and which is black.
  3. Install the black cartridge in the slot on the left and the color cartridge in the slot on the right
  4. Close the ink cartridge lids and make sure they lock in place.
I hope it helps!!!
Nov 18, 2008 | Dell 924 All-in-One InkJet Printer
Ink cartridge carrier jam
If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
Aug 21, 2008 | Dell 926 All-In-One InkJet Printer
Printer mp130
take the ink cradle out and take the cartridges out. clean the print head on cradle with alcohol, and you might wanna try blowing the ink residue out of the head becuase the black ink cartridge leaks
Jul 10, 2008 | Canon PIXMA MP130 All-In-One InkJet...
C60 says full cartridge is dry
You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
Change the cartridge when prompted.
Of course, having messed about with the jet, it may not work now !
Jun 05, 2008 | Epson Stylus C60 InkJet Printer
HP OfficeJet k60 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
