Question about Maytag Neptune MAH5500B Front Load Washer
No hot water
My maytag neptune mah4000awq has been pretty reliable other than the famous mold issue. now no hot water is dispensing. troubleshooting it leads me down to the solenoid. cannot find a replacement part due to age of system. any suggestions?
  • Debbie c Feb 10, 2009
    I have the same problem with no hot water. It took me a long time to figure out what was going on. My clothes kept coming out with soap, and my washer would stop and I'd have to restart it. I've been using cold water until we can get it fixed.
    Debbie C
    Scholar:
  • 79 Answers
I would remove the machine control board located behind the timer and see if there are burn marks on the copper traces on the backside of board. Some boards arc over and this causes the water valves to not work properly.
The control board will have to be replaced if it arced over.
See www.neptunehelp.com for more dissasembly photos and details.
Have you changed your faulty door latch wax motor? See www.neptunehelpsong.com for a video that explains the issue.
Posted on May 23, 2009
I have had two bleach dispenser valves fail in the past two years on my Neptune TL washer. They simply won't dispense the bleach from the reservoir. Is there any underlying problem that may cause...
Maybe the water channel leading to the dispenser valve is not aligned......lid bowed? See Pic
""I have had two bleach dispenser valves fail in the past two years on my Neptune TL washer. ""
Describe fail......did you replace the valves or a repair service?
If you did the work what troubleshooting did you do on the valves? Did you check for 120VAC applied to the valve in Service Mode? Maybe the relay that applies 120VAC to the valve is not functioning or working intermittently........see pic of schematic of Control Board K3 is the Bleach Dispenser relay that applies 120VAC to that dispenser valve. Is it working 100% of the time? If not it may be a Control Board or connector issue ......but you need to troubleshoot.
Did you power up your old dispenser valves with a 120VAC cheater cord on the work bench to verify operation Open/Close?
I'm an owner not a appliance repair tech but have a electronics technical background.
Aug 21, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
I can't see it but my maytag neptune has moldly smell. How do I get rid of it?
Maytag's solution was to run an empty load using hot water and a cup of bleach instead of soap. According to them you are supposed to do this quite often. If the rubber ring that seals the door gets mold on it you are supposed to use a water/bleach solution and wipe it down with a rag.
Feb 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune TL fabric softener cup seems to be clogged, what do I do?
If your machine is a FAV6800AW/FAV9800AW see if this post will help you. Once the Fabric Softener top is removed you can flush the dispenser and run some pipe cleaners thru the exit ports to help remove gunk build up.
If there is a water flow issue into the Fabric Softener dispenser then further investigation may need to take place. I discuss how I would start the troubleshooting for that as a possible issue.
The Service Manual for reference use and care guide has some info
Rich
Nov 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Softner cup is not draining completely on Maytag Neptune TL
Dot,
If your machine is a FAV6800AW/FAV9800AW See if this post will help you. Once the Fabric Softener top is removed you can flush the dispenser and run some pipe cleaners thru the exit ports to help remove some gunk. If there is a water flow issue into the Fabric Softener dispenser then further investigation may need to take place. I discuss how I would start the troubleshooting for that as a possible issue. Rich
May 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer model #MAH4000AWQ
The famous Q6 and R11 failure can cause this issue. Have you replaced the faulty door latch wax motor yet? See www.neptunehelpsong.com for a video that explains what happens.
The Q3 triac (same part as the Q6 triac) will need to be changed on the board or the control board will have to be replaced along with the door latch wax motor if yours has the brownish color actuator pin. The new design has a black actuator pin.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer dispenser unit has mold and mildew inside top of dispenser compartment.
You can pour the bleach in the drawer every time you do white loads and it will stay clear too!
Just flush it out good before you do colored clothes or you may get a small bleach spot on a red shirt !
Neil
Ps. Give me a problem solved rating here on fixya.com
Aug 19, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag neptune
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
Apr 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune on/off button wont stay on
You have to investigate where the burning smell came from. Start at the timer and then check the main board. Also check the drain pump.
Oct 23, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
82 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
