Question about Maytag PYE2300AY Electric Dryer
MAYTAG PYE3200AYW, WILL NOT RUN, PRIOR TIMER PROBLEM
My Matag dryer wll not start, it had a timer problem were it would not shut off for a couple of days, now it will not run at alll. It is possible that it ran all night at the hands of one of the teenagers. Is there a "home owner" fix for this problem. I am pretty handy, have hand tools, and a multi meter. I have most of the covers off looking around for a blown fuse or the like right now.
  • james_mannin Jan 14, 2009
    yes, it was heating, no breakers are tripped. Is there internal fuse/reset or the like. I have the top cover, as well as the housing around the timer open, nothing is smoked or discolored. If yur best guess is the timer, I may just may swap it our and see if that will do the trick. Are there some points that I can check with a meter, to tell me if the timer has an open or short circut?
  • 979 Answers
When it ran all night was it heating then? Are any of the breakers tripped? Are the connections secure in the back? But I believe if the heat was working when it was running, the timer may be the problem and they are simple to replace and not that expensive. If this unit is older than 15 years, then it may be time for a new one. The parts and time wasted may be better spent on a new one.
Posted on Jan 14, 2009
  • Bill Dickerson
    Bill Dickerson Jan 14, 2009
    Yes, my best guess is the timer. Since you have the top off, look for the a thermal fuse. It may be shaped like 8-10 stacked nickels. Bypass the fuse and connect the two wires to see if it will run. If it does, then replace it and your back running again. If not, it is most probably the timer.
Maytag dryer model number PYE3200AYW stopped working and no light comes on when door is open
check the door switch:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 30, 2010 | Maytag PYE2300AY Electric Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
My PYE3200AYW runs but will not heat. Changing
Check for a blown thermal fuse or a faulty heating element. Both components should be located inside the rear of the dryer2.gif. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity will indicate a faulty component. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 08, 2009 | Maytag PYE2300AY Electric Dryer
The Dryer stopped and will not start again
Just had a similar problem with our Maytag Electric Dryer. The dryer shut off mid-cycle and wouldn't start again, but the timer kept running. We purchased a "Thermal fuse replacement kit" at a local appliance parts store for $38 and replaced the fuse ourselves. The dryer is running great! Here's a couple of website links that were helpful in figuring out out how to replace the fuse: http://www.partselect.com/repair.aspx?appliance=dryer&part=replace-thermal-fuse
http://www.davesrepair.com/DIYhelp/DIYthermalfuses.htm
Hope this helps!
Jul 09, 2009 | Maytag PYE2300AY Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Matag gas dryer does not shut off. Is it the sensor?
Hello, I would say if the timer keeps going around and around. I would say you have a bad timer.
Jan 04, 2009 | Maytag Dryers
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer starts to heat then it stops #pye3200ayw
There are a couple of things that could be causing this problem for you. First off check and make sure that you have good air flow coming from the vent outside the house. If it feels weak then that is probably your problem. If there isn't enough air getting out the thermostat will shut off the heating element for safety reasons. If the air flow feels good then the problem is probably with your thermal fuse. That is a nice cheap part running around 15 dollars at your local appliance repair shop. The thermal fuse is located on the heating element housing and has two small wires coming off of it. Make sure you unplug the dryer before working on it though. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Timer problem
Found on partselect.com MAYTAG
Wiring diagrams:
http://www.partselect.com/Schematics/Maytag/52485.gif
data on the whole thing:
7 diagrams
Sep 24, 2008 | Maytag PYE2300AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
123 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
