I am in need of set up instructions for a Dayton Heater model 2E214. Is such a manual available?
    Guru:
  • 462 Answers
IF SO wwgrainger.com can find out for you.
Call their 1-800 number and make a request.
Please grade me accordingly and if you need more I need more information. THANK YOU AND GOOD LUCK!
Posted on Mar 02, 2009
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
How do I wire up a Dayton model 2e214 to run a 110 volt engine block heater ?
i run my block heater offf a simple lamp timer that i bought at the hardware store , much simplier to do than the hvac timer you have there
Feb 28, 2015 | Dayton Heating & Cooling
30 yr old Dayton timer 2e214 clock motor good gears good, however dial movement spins freely
Dayton 2e214 is Grainger number that corresponds to Intermatic 120Volt T7801B 7-day timer.
http://www.grainger.com/Grainger/INTERMATIC-Electromechanical-Timer-2E214
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/24%20hour%207%20day/t7000b%20series%207-day%20time%20switch.aspx
If the dial rotates freely, the gears are probably worn out or the clock motor is not connecting to gears any more, or the dial has come loose.
The replacement clock motor is WG1600-11, BUT I don't know if that motor will fix problem.
Turn power off, and release mechanism using thumb spring located top inside box and inspect gears while rotating dial.
http://waterheatertimer.org/pdf/Parts-accessories-158-162.pdf
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html#clock
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 07, 2011 | Amperite Dayton Solid State Timer On Delay...
I have a Dayton time switch hot water heater timer model 2E214 7 day timer in a house that I just bought. Don't really understand how to use it. Where can I find a manual or user guide? Or can someone ...
1) Dayton 2E214 timer is Grainger number for Intermatic 7801B timer.
http://www.grainger.com/Grainger/INTERMATIC-Electromechanical-Indoor-7-Day-2E214
2) Grainger page also show extra on-off trippers for the timer
3) Same/similar timer shows for water heater on following link:
http://waterheatertimer.org/Boxtype.html#T7400
4) I have a similar manual in my files:
http://waterheatertimer.org/pdf/t7802b-2no-2nc.pdf
5) Intermatic site is offline this weekend but link to iNTERMATIC manuals is following:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/7%20day%2040%20amp.aspx
6) If link above does now show exact product, then type Intermatic model number into search bar, and it will show manuals.
7) To operate the timer, attach silver and gold trippers to face of dial. See image below of Intermatic 24-hour dial.
The trippers are labeled on and off.
Buy more trippers at grainger if needed.
ON tripper pushes lever that closes circuit and turns water heater ON.
OFF tripper pushes same lever other direction that closes circuit and turns water heater OFF.
Dial rotates as time passes.
To set current time, rotate dial until current time lines up with pointer. The pointer is stationary.
I believe this model has to be reset after power outage.
8) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 19, 2011 | Kitchen Ranges
I am looking for A [3 ea] and B [7 ea] trippers for a Dayton 2E214 timer??
Dayton 2E214 timer is Intermatic T7801B.
Open following Grainger page, and it shows correct tripper:
Same tripper is used for T100 series and WH40.
Feb 28, 2011 | Hardware & Accessories
I have a Dayton 3VU32 heater. The fan does not turn when the switch is on fan or the other 2 heat settings. The heater does produce heat. Is there a solution, are parts available and where?
Dayton is a Graingers brand. Please contact Graingers at the web site below to see if parts are available. It may be cheaper to just buy a new heater. Hope this helped you...Jim
Feb 12, 2011 | Dayton Heater,Space,120v
I need a service manual for a Dayton oil fired 350,000 BTU heater.
I have a manual for a Dayton 3E218E. If you want a copy email me at Edwards0202@aol.com and put "HEATER MANUAL" in the subject line. I can scan it in and email it back to you. This manual is for 2E510F, 2E511F, 3E218E and 3E219E. I also found a great web site for parts for all these models as well:
http://www.bealsmotor.com/
Nov 30, 2009 | Dayton E50 Heater
Ned a fan moter for dayton model 3vu36a heater
consult with WW GRANGER. They have Dayton as a line and will be able to tell you whats available from model number. They also have a web site with phone number to their stores. try it w dot com.
Jan 10, 2009 | Dayton Electric Heater
Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Dec 07, 2008 | Dayton (3E379) Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
