Question about Vizio L32 32 in. LCD HDTV
Goes black on lower half, part time, 3 cable channels only
VIZIO L32 in. HDTV LCD TV operating in analog mode, connected to
Mediacom cable, screen goes black on the lower half, part time,
when channel 8, 12, or 63 is selected. All other channels, including
the available HDTV channels are OK. The set is 2 years old with
no trouble. I am located in Springfield MO.
M.B.
  • 565 Answers
Scan your channels again in those three channels maybe have a bad frequency also try to reset your tv to factory setting before it
Posted on Jan 14, 2009
  • 10,594 Answers
Its bit confusing problem as TV screen goes lower half black in particular few channels.
I would suggest to preform auto-preset / auto-search again to get correct available channel data in TV memory.
An other try is to unplug TV from AC outlet for few minutes and replug it back and check on channel 8, 12 and 63.
How to reset lg motel model tv
Go up on Visio's web site. They can tell you what the steps are to get to the special setup screen on the TV.
Dec 30, 2013 | Vizio L32 32 in. LCD HDTV
My tv just turns to av1 how can i get it go to the channel to watch tv?
Hi Cayla,
What channel or input the TV is usually on to view programming?
Tommy Faust
DISH Network
Nov 17, 2011 | Vizio L32 32 in. LCD HDTV
My 32" Vizio when not on a HD channel has a
could possibly be a Line noise issue from your cable provider, if it's an analog signal. I would try another room in the house to see if your problem goes away. If not, it may be something your cable company may have to look into. This may also be associated with intermittent connectivity if you have cable internet as well.
Dec 08, 2010 | Vizio L32 32 in. LCD HDTV
I can not get channels on my vizio hdtv. i have a cable cored hooked up to the tv and i can not get the channels to come on the tv screen. it keeps saying "No Signal!"
You will need to make sure that your cable is connected to the correct input (if more than one) and then enter the Menu and look for a "set up" screen and select "Scan for Digital Channels".
After the scan the TV should be fine.
Jun 14, 2010 | Vizio L32 32 in. LCD HDTV
WHEN I TURN ON MY L32 I GET NO PICTURE. I GET BLACK SCREEN THEN LOTS OF COLOR, REDS ,BLUE ,ALL COLORS IN DIFFERENT PATERNS THAT KEEP CHANGING. SOUND IS PERFECT AND I CAN CHANGE CHANNELS AND VOLUMEAND...
It sounds to me like it's stuck in service mode.There is a button combination with the remote to return it to normal. I would call Vizio support and they should be able to help you.
I think it's a combination like [volume -], [channel -] and power but I could be wrong.
Dec 19, 2009 | Vizio L32 32 in. LCD HDTV
When I connect my computer to the tv it starts fine and then goes to no signal.
Make sure tv is set to proper input.Make sure that cables are properly plugged in to the right channels.
Hope it helps,,
Thanks
Sep 07, 2009 | Vizio L32 32 in. LCD HDTV
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Mar 01, 2009 | Vizio L32 32 in. LCD HDTV
Black Rectangles on 42" Vizio HDTV LCD
Your DirecTV signal is probably too low. That would produce the small black rectangles (pixilation). Also, try replacing the cable you are using to get the signal from the DirecTV receiver.
May 20, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
