Question about Philips TP3681C 36" TV
TV will not turn on.
Techman responded to another post stating that it probably was not the picture tube. He asked for more info. Since I have the same problem for the same TV and it definitly is not the TV power cord or the socket, etc. I thought I would give you : The chassis number: 36D7007570 The model number: TP3682C101 The serial number: 14430134 My son says that he can here a high pitch noise when the TV is plugged in. He can hear it, but I cannot! When the TV is plugged in, the back does not get warm. Is there anything else you need? Please let me know if you can help. Thank you.
    President:
  • 3,130 Answers
A high pitched whine is most of the time the power supply trying to run, but it is being loaded down from a short somewheres in the set. Sometimes a resistor on the CRT board will open and make the set shut down right after start up, sometimes the horizontal output transistor causes this problem, almost any circuit for that matter can cause this problem. Good Luck
Posted on Jun 14, 2007
LG Golden Eye CRT not working as it was fell down from Table what may be the probable reasons?
If the picture tube neck has got any crack, the TV wont switch ON. Check it. If the circuit board inside have cracked, the TV won't switch ON. Your TV need a through check up. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 24, 2014 | Televison & Video
Tv repair
I have no idea on what youre needing, unless you respond to the origional post I have no way of viewing previous posted info. Could you please state what it is that you need help locating?
Jul 27, 2008 | Philips 60P8341 60" Rear Projection...
TV problem
can you describe what type of problem the picture was having before it went out/ Also need the model number of your set. Please respond to this same post so the previous info is available when You post the model number.
Jun 27, 2008 | Televison & Video
GE Television Dark Shadows
If you are comfortable working inside the set, I can suggest the following:
1) Open up the back and locate the flyback transformer (part with large red wire coming out the top). There should be 2 adjustment posts on the back of it.
2) adjust the top one slightly clockwise as you are facing ht back of the TV. This should cause the overall picture to brighten. Don't turn it too much as you will then see the "retrace" lines.
3) Adjust the lower one to focus the picture.
That should help a bit. If not, then the picture tube is probably at the end of its life. Keep me posted with your results.
Dan
May 24, 2008 | Televison & Video
TV picture
The set you have has a bad tuner assembly. At this point most likely you would be better off getting a new TV set. Good Luck
Mar 30, 2007 | Mitsubishi CS-27309 27" TV
TV has audio sound and no picture
Your set migbe missing the high voltage that lights up the picture tube,you need to check for loose conections starting at the horizontal drive transistor and transformer ,then check the horizontal output transistor for short,it needs to be checked with a meter if the output is shorted it probably open a safey fuse or resistor to prevent more damage.If you are familiar with tv service this will give a place to star but if you are not too familiar be safe and seek the help of a servicer.Let Us know if you need more information.
Oct 14, 2006 | Sony KV-36XBR400 36" TV
Tv flashing
I could be wrong, but, from your description it looks like a cold solder, most probably in the Filament Heater circuit. If you are well versed in Solid State Electronics, I suggest you look for a loose solder or joint. Shut OFF the TV, Open the rear cover and chech for any dry dolder or loose coonections. Start with the CRT Neck PCB. Follow the tracks from the two Heater Pins (Marked H H) on the base). Also, gently remove the Neck PCB gently from the Picture tube, and (very carefully, mind you!) clean the Picture tube Contact Pins. Again, very slowly and gently, replace the PCB. Try your TV again. Let me know if the problem is solved. As for the second problem, ( less brightness) how old is your TV? Over time the emission from the Picture tube Electrodes becomes less, and picture quality detoriates. If set is over 6-7 yrs old, or if you are a heavy user - that is, you have your TV switched on for 6-8 hours a day, it is time to go for a trade-in. But, if you are very attached to the TV, you can always take it to a service shop, where they will re-condition the Picture Tube for a modest amount. It's life will get extended by a couple of years.
Sep 14, 2006 | Sony KV-35V35 TV
How can I unlock the TV?
Try pressing the "F" or function button and hold while pressing the Mute or "M" button at the same time. Good Luck
Sep 07, 2006 | Apex Digital AT2002S 20" TV
Question for Techman
Sorry DrMike, I thought you could set the timer to 0. You did state that the timer was set to off correct?Let me do a little asking my LCD buds in the repair field.
Jul 30, 2006 | LG 42LP1D 42 in. LCD HDTV
TV wont come on
Most likely cause would be a blown fuse on the power supply if you are getting no lights on the front, no response from the buttons, and no warmth from the back of the set. First check that not only is the power socket in the wall working, but also that the plug on the TV power cord is not faulty or distorted so it doesn't make the circuit when plugged into the wall, also if it has a fused plug, check that. Then if you feel up to taking the cover off, make sure the set is unplugged and leave it for a few minutes first. take off the back cover (usually a few screws around the base of the set, but it should be obvious) follow where the power cord enters the box, and about the first thing it should connect to is likely to have a fuse. Probably a couple of metal spring clips with a glass tube type fuse sitting in them. The fuse should have a rating stamped on it and you should be able to get a replacement at most hardware stores, but make sure you get the same type as well as rating. If a replacement fuse doesn't cure the problem then the next thing to suspect would be the transformer and rectifier circuit - the fuse should have protected these, but sometimes it doesn't work that way. If you need help checking these then please ask again, but I suspect the fuse is your problem. Hope this helps you out, please ask again if you need more info :)
Mar 24, 2006 | RCA F32450 32" TV
Televison & Video Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
