Question about Kenwood KAC-X501F Car Audio Amplifier
Blown amp, on circuit board, connecting fuse and power connect.
2 boss C450 chaos 2CH 600 watt amps. i accidently, put the GND wire in the power port, and the power in the GND port. there are 3 wires that connect the BATT-REM-GND to the fuse port inside the amp, on the circuit board. is there any way to repair that or is the amp trash?
  • 15,935 Answers
These amplifiers dont employ reverse polarity protection that most higher priced ones do.
The amplifier(s) are definately in need of repair - probably power supply - IF boss sells parts.
Chances are, however, the repair will meet or exceed the cost of a new (appropriately rated) entry level amplifier.
Just about anything can be repaired.... question is, are you willing to pay?
Posted on Jan 14, 2009
2 Suggested Answers
  • 74 Answers
SOURCE: 2 boss C450 chaos 2CH
open the amp and see if anything was blown inside, if not check replace the fuses, and re connect.
Posted on Jan 16, 2009
Why am i not getting any sound to the speaers of my boss chaos 2800 watts amp?
Most common problem is cable connection. Wiggle each lead, positive, negative in turn at amp. while playing. I assume you have checked that you haven't inadvertently muted the system.
Mar 18, 2017 | Boss Car Audio & Video
Protective mood
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Hopefully its not toast. .A thumbs up would be greatly appreciated if this answer is helpful to you. protective-mood-zb4bomd1rt4qms0dqd12kkt2-2-0.jpg
Jan 16, 2014 | Car Audio & Video
Can my la590 American legacy 2 series 800 watt handle Boss CX122 Chaos Exxtreme 12-Inch Subwoofer 4-Ohm Voice Coils??
It is only stable to 4 ohm mono(which is 400 watts RMS or a bit less not the max rating of 800 watts which is a PMPO rating).
Your Sub would have to be wired in series(8 ohm final load, if you wire it in parallel 2 ohm-you will fry that amp).
Jan 07, 2014 | Car Audio & Video
I have a boss chaos c-650 amp. channel 3 and 4 work fine but i get nothing from 1 and 2. i opened the amp n realized that one of the fuse holders had gotten detached from the circuit board. could i just...
the fuse holders are for the channels if 3/4 work an 1/2 dont an the fuse holed is disconnected , try turning on ur amp an playing a song an pull out the fuse that is connected to the bored an see if it stops playing if it does then , u would have to hook that other holed up to the bored where it was before
Jun 09, 2011 | Boss C650 Car Audio Amplifier
When I connected my 12V and GND wires and the power light did not turn on. What should I do to give the amp power and make it work?
When I installed mine I had the same problem because my Remote Power wire didn't have a good connection to my head unit, I would just double check that along with making sure your GND wire has a solid connection to metal (make sure you remove paint if there's any on the metal). Make sure none of your fuses are blown of course and that you have a solid connection to your battery as well. I only ever installed one setup (my own) but I hope this helps some.
Feb 08, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Does this boss chaos c550 amp match up to perform correctly with 2 12inch kenwood peak power 600 watt magnet 500g (17.6)oz impedence 4 ohm kfc-w300s speakers
It's not bad, but at 400 watts, it's a bit underpowered
It'll be plenty loud, but the amp will distort before the speakers do, particularly if your subs are wired in parallel (as dual-driver boxes are typically wired)
Listen for distortion, and turn it down a bit if the sound gets fuzzy or static-y sounding
Feb 03, 2010 | Boss C550 Car Audio Amplifier
How i wire my sub to my jbl gto301-1iiamp with 2 Hifonics HFi12D4
If the amp is 1200 watts at 2 ohm stable you will want to set up the speakers as parrallel and bridge the amp. That means conncect the speakers with + to + and - to -. Look at the amp connections. Usually thereare connects that look like this:
If yours look like this use the diagram on top. You will use the + for the left ouput on the amp to the right - on the amp. This will allow you to use all the power from the amp. Be sure to lower the gain as to not pop the speakers or amp.
Nov 17, 2009 | JBL GTO 301.1II Subwoofer Mono Amp - 200W...
Boss c705 chaos "manual" try-en to find
What info do you need? All amps are exactly the same and the manual only differs for specific specs and db ratings!!
Nov 03, 2009 | Boss C700 Car Audio Amplifier
Amp keeps blowing the fuses
Serious short circuit on your output transistors, need replacing.
Sep 28, 2009 | JVC KSAX4504 MOSFET 600-Watt Amplifiers...
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
Jul 30, 2009 | Computers & Internet
Kenwood KAC-X501F Car Audio Amplifier Logo
304 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
