Question about Canon CLC 1150 Color Copier
Startup Password Hi Does anybody know how to reset the 'department password' , ID and any other password when the copier is powered on? There is also a RIP attached to the copier but I'm having a few issues logging into it. Many thanks.
  • 62 Answers
Press *, 2&8 (at same time), then * again to enter service mode. Select FUNCTION from the icons along the top of the screen. Press Clear and find PWD-CLR. Press PWD-CLR and press ok. Press RESET (yellow button) twice to exit service mode. Password should be removed.
Posted on Aug 27, 2007
Canon IR c6800 department password
You can just reset the password if you dont have it by doing this,
press additional functions
2 + 8 simultaneously
copier
clear
right arrow button
PWD-CLR
ok
turn off then on the power switch on the right hand side of the copier.
Dec 10, 2010 | Canon imageRUNNER C6800 Copier
Today I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution...
oday I start my printer canon ir 2520 and i see dept id and password prompt screen, I did not reset any id and password earlier, I cannot go inside the menu or i can't take any copy. Please give solution for disable or reset the same.
Oct 23, 2010 | Canon iR 2022 Printer
I would like to Reset/Retrieve Password for Copier Setup Canon, ImageRunner canon ir 2318
If you know the password, then under user mode, i think system sett., must be option for department id management where you can change passwords.
If you dont have pass, you can do clear all under service mode ( * 2 8 * ) if canon changed service mode, like on some series, you can try MENU and #.
Hope that helped
Jun 29, 2010 | Canon imageRUNNER 2200
Purchased used wt9235le and don't know logon id or password,how do i crack
Hi, if it is similar to the 3235LE you can reset them by holding down the "p" key whilst powering on the device.
Jan 20, 2010 | WYSE Winterm 3235LE (90202401R) PC Desktop
Startuo ask for Depart ID and password
You need to turn dept id off but to do this you'll need to clear the system password. You need the service mdode to do this. Press the head key once (the key with a head and star inside) then the 2+8 keys at the same time, then the head key again. This will get you into service mode. Now select 'COPIER' then 'FUNCTION' then 'CLEAR' now look for the option the reads 'PSW-CLR' select it and press OK. Now turn off the machine by the control panel and then the power switch. Now turn the machine back on and you should be ok.
Jun 17, 2009 | Canon Office Equipment & Supplies
I forgot my password
If it is the system manager password, the one for the web management site, you will need to have a dealer or technician reset that in service mode.
If you are talking about your department ID code, you will need to talk to the person who manages those IDs.
If you are talking about a mailbox password, you should have your system manager reset your mailbox.
Apr 26, 2009 | Canon NP 6050 Copier
My son has forgotten the password for the windows liveID account
The 360 and xbox.com uses your Live ID as your login. Instructions for changing your Live ID password can be found here.
http://support.microsoft.com/kb/906928
Apr 08, 2009 | Microsoft Xbox 360 Console
Admin password for Canon ir2270 MFC
JUST HAD THE SAME PROBLEM. THE DEFAULT ADMINISTRATOR PASSWORD IS "BLANK" LEAVE THE PASSWORD FIELD EMPTY AND PRESS ENTER
Mar 17, 2009 | Canon Office Equipment & Supplies
Dept number and Password
You can turn off department id codes from the additional functions menu but you will need to know the system manager id code to perform this. If you cannot obtain the system mgr ID code from the people you purchased it from it will require a reset done in service mode.
I might be able to help if you cannot obtain the System Manager ID code to get into the admin settings.
Hope this gets you in the right direction
TankMurdock
Feb 25, 2009 | Canon imageRUNNER 210S Copier
How to reset copy count limit
press (*) > (department id management)>(store dept id/password) then u can change your copy limits
Feb 13, 2009 | Canon imageRUNNER 5000 Copier
Canon CLC 1150 Color Copier Logo
305 people viewed this question
old marine
old marine
