Can get tv vert and horizontel back on track
I count roughly around 36 small knobs to turn, is there a reset button or somthing model is vs-500-4r projection.
  • 90 Answers
There is no reset button for this. Chances are that you have a problem with your convergence circuit. If only an adjustment is needed, you will still have to generate a crosshatch on the tv to do the alignment...usually a job for a professional.
Posted on Jan 14, 2009
Nordic track treadmill console is faulty
Dear Sir:
The problem is a( Faulty batteries b( Tight the flexible cables from keypad vs display board 3( tight the connector from display board vs lower board 4( adjust the Reed switch see the diagram for ilustration 5( Main motor board is faulty.
Try to run the software calibration for diagnose and trouble.
See my personal TIPS for HELP.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 11, 2012 | Nordic Track NordicTrack COMMERCIAL 1750...
Main setup menu froze on screen unable to remove,also TV just stays on have to unplug from outlet. Press Rest button, and home button on remote nothing happens. Do have background channel TV from cox cable...
If the model number posted here is correct (vs-70707) this is a VZ8 Chassis made around 2000 and should NOT have a reset button on the front.
Please confirm actual model number.
Note: almost all Mitsubishi sets have a hidden menu (two or more) and one allows with the Mitsubishi remote to enter for example the OPTION menu and there you will be able to do a HARD RESET on the set which sets ALL settings back to default.
sj
Oct 20, 2011 | Mitsubishi VS-70707 70" Rear Projection...
When I turn it on it acts like it's gonna come on then it doesn't the lghts around the Ipod holder just flash and it cuts off
If you go jvc .com enter your model # ,there is an article on how to reset the tv. First you have to unplug your tv for 10 secs., plug it back in and press and hold the menu and vol- buttons while holding these buttons in press the power button once, count to 3 and release the menu and vol- button. The lillte blue light should be on. wait for 40 secs. the picture should now come back on. This worked for me, I had the same trouble
Apr 19, 2011 | JVC LT42P789 42 in. LCD TV
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
Hqw can I adjust the vertical hold on a 36" sharp tv. it is built in and not easy top access the back
That's not the vert. hold...that for the vert col on the flyback...don't touch that! You need a service remote control to adj.vert and the right codes
Apr 03, 2010 | Televison & Video
Sony FD Trinitron WEGA Won't Turn On
The key here is the count of the blinks. I'm assuming that the model number is KV-36FS120. Please post the blink count. It should be a count-pause-count...
Thanks,
Dan
Jul 28, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
36afx61 vert problem
What is the vert problem? Usually, a break in the foil indicates separation of ground planes, but they will converge to a single point somewhere. If there is solder that ties the planes together, this may suggest that someone has modified the board. Again, what is the problem with the TV?
May 13, 2007 | Toshiba 36AFX61 36" TV
Picture too big
you mean too big from side too side or top to bottom?? if its all the way around is there a zoom button on the remote??? if ita too big from top to bottom a part might have changed value in the vert sweep curcuit. You could very carefully take off the back and find a small pot or control in the vert cuircut and bring down the picture But I dont recomend this if you have no knowlege of tv curcuitry.
Apr 04, 2006 | Curtis-Mathis CM27101S TV
65 inch Mitsubishi tv Model # vs-60703
so does it have sound??? If so then the set is probably in a hv shutdown because of a weak tube or is in vieo safty mode as the vert has failed in the set. On cost here in Michigan a tube could cost up to 300 bucks + labor and on the vert repair about 250.00 to 400.00 to fix
Mar 30, 2006 | Mitsubishi VS-60703 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
