Question about Epson Stylus Photo R200 InkJet Printer
Epson R200 Just replaced ink cartridges. Ink LED stoppped flashing. In printer monitor software message says (Yellow !)'PRINTER NOT READY TO PRINT Check all connections and make sure all devices are on. To cancel printing, click the Cancel button.' Printer is on. USB cable is connected.
  • 1 more comment
  • mark buckley Jun 14, 2007
    Yes to both. Have downloaded and reinstalled driver from Epson to no avail. This was after trying to uninstall Espon monitor software. XP would not let me due to 'memory error' but the program seems to have gone anyway.I cannot find the original CD.
  • mark buckley Jun 15, 2007
    OK. Thankyou very much. I will keep you updated.
  • milan joshi
    milan joshi Mar 22, 2014
    ok Thank you very much
  • Epson Master
  • 691 Answers
Does the error remain when you remove then restore power to the machine? Also reboot the PC.
Posted on Jun 14, 2007
  • Inky Fingers
    Inky Fingers Jun 15, 2007
    It sounds like a remnant of the Status Monitor may be fouling the set up. I suggest you try removing the status monitor and the drivers etc again.
    Once removed, reboot the PC and try to install the driver only. Reboot the PC and then download the latest version of the Status Monitor and install that. Reboot the whole lot again and see how you go.
    Removing a remnant can be a real hastle and it is often better to re-install an application then remove it to try and recover the failed un-install.
    If you still get no joy, try calling Epson. They can sometimes to be very willing to help with such things even when out of warranty.
My espson R200 won't print black even though it is full :s
> ESPSON
ESP-son? EPSN-Sports-Online?
Use the EPSON software to run a "print-head-cleaning" cycle to try to "unclog" the path that the ink takes from the ink-cartridge, through the "jets" onto the paper.
Nov 17, 2010 | Epson Stylus Photo R200 InkJet Printer
Need to change ink catrege help
Using the printer's control panel In some circumstances, you may need to replace an ink cartridge before it is empty.
If the fonth.gif ink out light is flashing or is on, replace the empty ink cartridge as described in Replacing an Empty Ink Cartridge.
To replace an ink cartridge before the fonth.gif ink out light flashes or the Status Monitor notifies you that the cartridge is empty, follow the instructions in this section.
r_caut.gif Caution: r_space.gif Do not remove the cartridge from the printer until you are ready to replace it with the other one.
r_1.gif Make sure that the printer is on. The fontp.gif power light should be on, but not flashing.
r_2.gif Lower the output tray, then open the printer cover.
r_3.gif Press the fonth.gif ink button. The print head will move to the ink cartridge replacement position, and the fontp.gif power light will begin to flash.
r_space.gif r_note.gif Note: r_space.gif r_space.gif Do not press the fonth.gif ink button over three seconds. Otherwise the printer starts cleaning the print head.
Jun 13, 2010 | Epson Stylus CX6600 All-In-One InkJet...
Replace ink cartridges
1 - Open the top lid 2 - Open the ink cartridge carrier 3 - Shake the ink cartridges 4 - Unpack the ink cartridges 5 - Remove the yellow tape from each cartridge as you get ready to install it, but not before 6 - Install each color cartridge into its corresponding color slot pressing down all the way until it "clicks" 7 - Close the ink cartridge carrier 8 - Close the top lid
At this point the printer should charge its ink cartridges. Let this finish before using your printer.
Hope this helps!
Feb 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
R1800 yellow ink out light on constantly
Do replacemen procedure from status monitor (How to..). When asked to replace ink tank, unplug and plug again all of ink tank.
Aug 18, 2009 | Epson Stylus Photo R200 InkJet Printer
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Photo R200 unrecognised cartridge message
Problem solved! I moved each cartridge up slightly to break contact and then snapped them back into place. Loaded a job up, pressed print and it started with no problem.
Jan 14, 2009 | Epson Stylus Photo R200 InkJet Printer
Both Red Lights Flash together green light off - no printing
Mine did that too but my power went out in the house.
So diconnected it and uninstalled ssc utility.
Then reinstalled.
Worked fine after that. Hope it works for you.
Dec 26, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson R230 ink & Paper Lamp Blinking
my epson stylus photo R230 Printer problems always
two red light blinking
please help me
thank you
Sep 29, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson photo r200 will not print
so after reseating all the cartridges and doing head cleaning from the computer / driver and still not getting any output on the paper :
if it´s not the printer - hopefully it´s the ink
have them replaced, contact the manufacturer
Dec 23, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus Photo R200 InkJet Printer Logo
282 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
