Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
Daewoo 42" Plasma dp-42sm lines in screen
I have a Daewoo 42" Plasma dp-42sm with a black line in the screen. I had two at first. I soldered both and one started to work. I checked  the other resister and it found it was bad. I replaced it and it still  doesnt work. Any know where to get a screen or I will just sell it for parts so if anyone needs any parts let me know. Just the screen is bad.
  • chastoes Jan 30, 2009
    I have 12 or so red & green vertical lines over signal display?Is there a mod to fix?
  • Anonymous Feb 28, 2009
    verticle lines through screen also ....on 46" model
The problem is you have a cold solder joint on a component on the flex harness. My son will show you have to fix it on YOUTUBE. Check it out!
http://www.youtube.com/watch?v=EFpXYnGZCU0
Posted on Sep 05, 2011
Hi Meadcorp
any chance you still have the power supply for the dp 42sm ?
Posted on Jan 20, 2010
    Problem Solver:
  • 8 Answers
Hello Medecorp,
I was hoping you could help me. You mentioned that you soldered both....I'm curious as to what you soldered. You can find a screen on Ebay. Thanks for your help. Vin
Posted on Apr 29, 2009
Screen showing three vertical black lines
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Apr 02, 2010 | Daewoo DP42SM 42 in. HD-Ready Plasma...
I have a daewoo plasma tv model dp-42sm with no video after taking back cover off found the x- sustain pcb with a burnt ic chip labeled iu4. after removing defective pcb and powering up tv set power stays...
I have the Daewoo Plasma Digital Dream model dp-42sm and it had power but no picture and my dads tv expert friend looked at it said the ysus board was out. I got the part on ebay for 125 dollars with 12 dollar shipping and put it in myself very simple and the problem is fixed. Is this the same issue your having?
Dec 17, 2009 | Televison & Video
Plasma 42" daewoo edtv black line down middle
Attempting the solder fix is a big undertaking, gaining access to the components is a MAJOR undertaking, and probably not worth your while.
If it is simply one line you might try the baseball Bat fix....
In reference to the "basebal Bat fix" it works on occasion by using percussive force to realign the ribbon cables.
DO NOT use a baseball bat, but use a rubber mallet and with the power off tap gently directly above and below the offending line.
Its worth doing this if yo cannot live with the line.
If you can live with it, leave well enough alone!
Oct 14, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
Daewoo Plasma dp-42sm
Just answered this on a different one. I have the Daewoo Plasma Digital Dream model dp-42sm, My dads tv expert friend looked at it and told us the ysus board was out. I got on ebay and bought the item from a store for 125 dollars used tested good with 12 dollar shipping, I put the part in myself it was very simple just take your time dont try and rush you have to take the actual bar the stand hooks onto off and the 2 boards going into the ysus board. It fixed the problem and is still in working order im using it now as the computer monitor.
Feb 28, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Apr 13, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
DP42SM image very dull
What might be happening is the backlighting and or its circuitry is going bad.
Feb 11, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
722 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
