Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Duet dryer won't move past sensing function on any cycl
Won't move past sensing
  • canchild1 Jan 21, 2009
    Display just shows sensing and will not start.
    Problem Solver:
Found the culprit. The thermal fuse was blown. Had no conductivity with ohm meter so I placed a jumper around it and presto dryer runs. Cleaned the exhaust and fan but found no blockage and really was not that bad. Hoping maybe just a weak part. The model on the Whirlpool Duet electric dryer is GEW9250PWL I believe the the last three are just the color. The part number on the Thermal Fuse is #3392519. This is easy to get to through the front panel just below the load door. Hope this helps some else out.
Posted on Jan 22, 2009
  • canchild1 Jan 22, 2009
    Thanx for the reply mrpham17. I just found the problem to be the thermal fuse. Thanx again
    New Friend:
What button do you press for diagnostics? i've tried everything. cant see a code
Posted on Jul 27, 2013
  • 54 Answers
Try holding down cancel button.. or a button that have a lock symbol... good luck
Posted on Jan 21, 2009
2 Suggested Answers
SOURCE: I have a Whirlpool Duet
try running a diagnostic on the dryer. You do this by making sure the power is off. Then push one of the sensor buttons (not the pause/cancel)
hold for 3 sec.
let go for 3 sec.
hold for 3 sec.
let go for 3 sec.
hold for 3 sec.
the lights will come on and 88 will show in the LED window. Then it should give you a F code.This website has a list of the codes and other instructions. http://fixitnow.com/wp/2007/06/19/whirlpool-duet-sport-dryer-diagnostics-and-fault-codes/
I ran the Diagnostic and it reset my machine and now runs fine. ( I had F-02) stuck button.
hope this helps
Posted on Feb 24, 2009
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
The light on my whirlpool duet dryer keeps blinking on all settings, won't start
push power button on push any cycle button hold down 3-5 seconds release push 4-5 times . if that don't fix it unplug for 30 min try that. let me know if it works might check lint trap also
Mar 18, 2013 | Dryers
Whirlpool WTW4950XW Washer won't go past the sensing cycle.
It may be as simple as a defective door switch or even a clogged drain hose (the hose between the tub and drain pump. Here are some videos that may help you more than i can. This guy knows:
http://www.youtube.com/watch?v=Aq7a3j7pFUM&playnext=1&list=PL5258B1D98A50745F
Jan 12, 2013 | Whirlpool WTW4950XW Washer
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
Whirl pool duet dryer not drying clothes
Inside the door under the filter housing is 2 strips that sense wetness. If they have dryer sheet goop on them they won't sense moisture. the dryer will therefore thank them clothes is dry. Clean them sensors with windex and party on!
Nov 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool GEW9250 Electric Dryer Logo
5,398 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
