Question about Seagate Notebook Hard Drives: 40GB (ST94011A) 9.5mm 5400RPM 2MB Notebook Hard Drive (DMST94011A)
Hard drive replacement
I have a gateway solo 5350 with win 98se
will a seagate st94011a hard drive work in the machine
    Scholar:
  • 177 Answers
I'll put it like this; The fact that it's and Ultra ATA 100 interface and that it's a 5400 RPM drive is somwhat of a concern.. Don't know if your laptop will support the 5400 RPM speed, but the good news is,it won't hurt your laptop to try it.
Also, I don't think the Ultra ATA 100 interface will be a problem, maybe require you to change BIOS setting (maybe).
Posted on Jul 24, 2009
Slave is ok but master freezes...
you can install even if it is a slave disk. also you can try setting the jumpers to master mode, check the sides of the hdd, it has a jumper setting and set it to master, using the shorting pin, just plug it out and connect it to the right setting
Jun 03, 2010 | Seagate Notebook Hard Drives: 40GB...
How do I replace the hard drive on a gateway solo 1450 laptop? I need to get the black plastic piece off so I can put it on the new drive
Hard drive replacement instructions (from the Gateway site) for your notebook are here.
http://support.gateway.com/s/Manuals/Mobile/8508627/8508627o.htm#1024735
The entire User Guide is here:
http://support.gateway.com/s/Manuals/Mobile/8508627/index.htm
Good Luck
Oct 21, 2009 | Gateway Solo 1450 Notebook
0x10090 error in st94011a hard disk
bad cluster.....or partition table!!!!
boott up winpe minicd....and make some changes...dnt forget format!!!! gd luck
Jul 13, 2009 | Seagate Momentus 40 GB Hard Drive
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Can't use install discs
why dont u using booting CD? it much more easier..
May 27, 2009 | Gateway Solo 9500 (3500847) PC Notebook
Hard drive from gateway solo pro 40 gig will it work in toshiba
I'm pretty sure it will. The only thing is that Gateways of that generationn used a custom connector which plugs onto the hard disks standard IDE / ATA connector.Just pull this extra connector off and you can use the disk in any machine.
Also ,Toshiba used similar adapters,so if Toshiba's using one on your model,then you'll need to palce the toshiba adapter onto the hard disk from your Gateway. You may also have to go into your BIOS ,and make sure the BIOS recognizes the disk if your BIOS isn't already set to "auto detect".
Mar 28, 2009 | Gateway Solo 9300 Series (5501056) Plug-In...
Hard drives show up in BIOS but not in My computer? WHATS UP?
You should not use line select on any of the drives at this point. Set the jumpers on the components to one master and one slave on each channel. Personally I would put one HD and one optical drive on each channel and make the optical drives the slaves but that's not required. Win98 uses a different file system than XP (FAT32 compared to the newer NTFS) but you can still use the drive. I would copy all the files you want to save and then reformat it using NTFS for better performance.
Boot into XP, both HD should show up when the jumpers are set correctly. If they still do not show up go into your BIOS and double check that all master/slave designations match what you have set the jumpers to.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
Seagate 320GB
It could be that it's formatted as NTFS, which Win 98 probably can't recognise. Problem is FAT 32 can't deal with drives over about 80 GB. There may be software patch out there to allow NTFS on Win 98, or (only solution I have used), you could format it as several partitions, including at least one FAT32 for your machine to see.
Sep 05, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
HDD not detected
plz try in another pc, if the problem remains then you contact the vendor
Apr 23, 2008 | Seagate Notebook Hard Drives: 40GB...
Gateway 5350 solo laptop
IF YOU LOOK AT THE TUITORIAL ON THIS LAPTOP YOU WILL SEE THAT THE MONITOR SCREWS HAVE TO BE REMOVED AND THERE IS A SCREW UNDER IT THE TUITORIAL THAT YOU HAVE ON DISC OR DOWNLOADED WITH THE MACHINE WILL SHOW YOU EXACTLY WHERE IT IS AND HOW TO REMOVE IT
Dec 08, 2007 | Gateway Solo 5300 Notebook
Seagate Notebook Hard Drives: 40GB (ST94011A) 9.5mm 5400RPM 2MB Notebook Hard Drive (DMST94011A) Logo
69 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
