Check ur alternator or crankshaft
ok, what do i have to check for?
the alternator i can check, but the cranshaft?
wait I cant check the alternator if the car is off dont I?
I had exactly same thing on my boat recently...which has a car motor in it. And I also charged the battery and I also had a reading that said I had charge. HOwever, I tried another battery from a car and it suddenly worked. Don't know why, but it really was the battery. When I put the old one back in, it still wouldn't start. With a new battery it's fine. Ya just never know why sometimes!! Good luck!
SOURCE: '91 honda accord battery light on with new battery.
either your alternator has gone or your fan belt is not there which helps the alternator to charge the battery get a volt meter on your alternator to see if it is kicking out what it should be
SOURCE: 98 Honda Accord Wont Start
either have a shop scan it for trouble codes or buy a scanner your self at local parts store have OBDII scanner and find out for your self it could be a number of things.
SOURCE: left key in ignition overnight, now car wont start
I have a 2005 honda odessey. I left the key in the ignition in the on position. The battery is dead. Do I have to recharge or will it recharge over night?
SOURCE: intermittently the car won't start. sometimes when
I think you answered you own question, when you said "it almost seems that the battery is dying," Drive it (while you can) to a parts store and get a FREE check of your charging system. They can tell you if it's the battery-low charge, which may indicate the alternator is bad- or a battery that is ready to retire, (and it also could be the starter, but I'm betting it's the battery). Let me know what you find.
