Question about Canon i850 InkJet Photo Printer
Flashing orange lights
Hi,  My i850 is sending seven (7) flashing orange lights and one green following.   I have cleaned the printhead and tried to reset the printer by disconnecting and reconnecting the electric cord.   Do you think I should simply buy a new printhead from Canon at this point?   Or should I  replace the printer.  Everything is operating but I suspect he prinhead may be leaking.
Thanks, Richard
  • 1,602 Answers
WASTE TANK NEEDS TO BE EMPTIED
GO ON LINE AND TYPE
CANON 850i INKJET PHOTO PRINTER 7 BLINKING LIGHT YELLOW
AND YOU CAN FIND YOUR HELP YOU NEED
ROD THE CANDYMANGNADY
Posted on Feb 04, 2009
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Canon i850 light is green then flashes orange 7 times then goes green and repeats orange flashing. Printer never gets ready
    This is a very bad error. It means that the printhead needs servicing and may need to be repaired. There is no easy fix. Sorry.
    Jan 21, 2010 | Canon i850 InkJet Photo Printer
    Light flashing green and yellow will not print
    Hi this is only a try it may work
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. Release RESUME
    3. Press RESUME twice, then release POWER
    4. Let green light blink until printer is done futzing
    Select function with RESUME press POWER to execute:
    presses - light color - function
    Number of presses - light color - function
    0 presses - green - Test print (or exit service mode on i960)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    Jan 14, 2010 | Canon i850 InkJet Photo Printer
    Printer Not Responding, 7 orange flashes
    Don't replace the print head soooo fast...
    Take the print head out first and clean the gold contacts...
    I used a very fine sandpaper like emery cloth...
    You might get 4 yellow blinks after that.
    That is because the printhead was turned upside down to clean and the ink looked low and/or out.
    Just wait a few minutes after cleaning and reset...
    Mine worked fine after that.... smile....
    Aug 09, 2008 | Canon S900 InkJet Printer
    Blank pages coming out of i850 with new printhead
    Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
    I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
    Issue: Certain colors are missing or no ink prints on the paper
    Solution: Install / replace the recommended ink tanks correctly i550 / i850
    Untitled Document How to install / replace the ink tanks
    The ink tanks suitable for the printer are as follows;
    Black Ink Tank BCI-3eBK
    Cyan Ink Tank BCI-3eC
    Magenta Ink Tank BCI-3eM
    Yellow Ink Tank BCI-3eY
    Note: There are two ink tank label designs.
    Operation procedures are shown with label design A.
    labelsa.jpg Replacement Procedure
    1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
    2. Remove the empty ink tank by pushing the tab on the ink tank.
    Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
    (The image is an example using i850.)
    3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
    Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
    Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
    (1): Correct
    (2): Incorrect (where the arrow indicates)
    4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
    5. Insert the new ink tank to the print head by holding it at a slight angle.
    Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
    6. Press down on the top of the ink tank until a click sound is made.
    7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
    May 07, 2008 | Canon i850 InkJet Photo Printer
    Printhead & Waste Tank Troubles
    Try this thread, it fixed mine without the need for any new parts, also note the cleaning procedure, it may fix your old printhead
    http://www.fixya.com/support/t350585-waste_ink_absorber_almost_full_canon
    Sep 15, 2007 | Canon S900 InkJet Printer
    Canon i850 7 orange flashes =Bad printhead????
    I had the same problm the printer made loud noises, the head did not move and the light flashed orange. At the right most position where the print head rests there is a gear, gunk had the gear jammed I cleaned it with a paper towel lots of black ink came out, it is working fine for a couple of days now.
    Apr 17, 2007 | Canon i850 InkJet Photo Printer
    Canon i850 InkJet Photo Printer Logo
    439 people viewed this question
    old marine
    old marine
