WLCB-54GT i hae wireless drive corega WLCB-54GT and when i make a setup for software the compute totally stop and i dont have just click ion power button to shut down , i have laptop compac evo n1020v
SOURCE: manual for compaq evo n1020v
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00089939/c00089939.pdf
Posted on Aug 02, 2008
biglala
  • 50 Answers
SOURCE: compaq laptop evo n1020v
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
a35
Posted on Dec 25, 2008
ginko
  • 19396 Answers
SOURCE: i need Evo N1020v agp dirver software.
Download from the web page below:
Compaq Evo n1020v Notebook PC - Download drivers and software - HP ...
Posted on Mar 04, 2009
Geekman
  • 32281 Answers
SOURCE: i have a compaq evo n1020v laptop,i connect to the
I assume you already have a cable or DSL modem and you were already connected to an Internet Service Provider and you no longer wish to connect to the Internet using your wireless card and wireless router.
THEN
1. Just remove the add-on wireless card from your laptop, no need to do anything on your laptop, if you wish to connect wirelessly again, just insert your wireless card and configure the wireless router again.
2. Turn off the wireless settings on your wireless router - you have to go into the wireless router configuration. This prevents anyone (unauthorized persons) accessing the Internet using your wireless connection.
3. Connect a network 10baseT cable to a 10baseT port on the router and the other in the 10baseT port on the laptop.
The network settings should be already setup for you to connect to the Internet (especially when you had access to the Internet previously), if not get back to me and I will give you further information/instructions.
Posted on Mar 27, 2009
Geekman
  • 32281 Answers
SOURCE: compaq evo n1020v not able to boot, no displal.
You have a sick laptop, could be simply a faulty power adapter to a faulty motherboard. The Evo is old and probably not worth fixing, better to put your money towards a new laptop.
There is a way to retrieve data from your hard drive provided it is not faulty.
Remove the hard drive from the laptop and connect it to an USB hard drive adapter. Insert the adapter into a working computer's USB port and the computer will see this as an external hard drive. You can then open the folders and view your files. Copy the various folders and files you require to a USB memory stick and/or burn these to a CD etc.
It pays to backup your data regurarly because if the hard disk fails and this can happen unexpectedly, you will lose your data.
If the hard drive is faulty, there are companies that can retrieve data from faulty hard drivers, but it will cost you an arm and a leg for their services.
Posted on Jul 06, 2009
How do I set up a valet m20 router with a computer that runs windows xp 2000?
Welcome to FixYa!
If you still have the installation disc that came with the router, you can go ahead and run the disc and follow the instructions. The Cisco Connect Software will be installed when you run the supplied Setup CD or Easy Setup Key on a computer. Once Cisco Connect is installed, you can then use its features to easily manage and share your network resources.
QUICK TIP: Create a Desktop shortcut to launch Cisco Connect easier.
Windows XP
Step 1:
Click on the kb21465-001_en.png button and select All programs.
Step 2:
On the All Programs sub-menu, locate and select Cisco Connect. This should launch Cisco Connect and take you to its main screen.
NOTE: If you are unable to locate Cisco Connect, it may not be installed yet. Download the latest Cisco Connect setup wizard from the Cisco Support page. After downloading, click on the Cisco Connect icon to launch the installation wizard.
Hope this will help...Thank you for using Fixya...
Feb 28, 2011 | Computers & Internet
Tip
How to Configure a Wireless Printer Wireless printers typically come with a...
Wireless printers typically come with a transmitter that a laptop, with a wireless adapter, can connect to and print from any location in a home. In order to configure a wireless printer you will need to install the drivers and software from the installation CD that came with the printer. You will be able to run the configuration for the printer driver, for the laptop, at the end of the software installation.
  1. Insert the installation disc for your wireless printer into the drive on your laptop computer.
  2. Wait for the Installation Wizard to appear.
  3. Click the "Next" button to continue and go through each screen to install the software for the printer.
  4. Select the option to "Configure printer driver now" on the last screen of the Installation Wizard.
  5. Click the "OK" button when the Information dialog box appears.
  6. Select the printer port for your printer when the Printer Port Setup dialog box appears.
  7. Click the "OK" button when the "addport" dialog box appears.
  8. Click the "Next" button to continue.
  9. Select your wireless printer from the list of installed printers when the Add Printer Wizard window appears.
  10. Click the "Next" button to continue.
  11. Click the "Connect" button when the Configure Printer Port dialog box appears.
  12. Wait for a connection to be made with the wireless printer and then click the "Finish" button to exit the Add Printer Wizard dialog box.
  13. Repeat this process on each computer that you want to connect to the wireless printer.
on Apr 02, 2010 | Computers & Internet
Have no setup cd with my belkin F5D7632UK4A how do I install it?
You dont need a setup CD as this is a router. you should have the manual which will explain in detail the process of installation. If you dont have the Manual as well, then provide the below details and i can help you fruther on this
Name of the ISP:
VPI / VCI value (to be collected from ISP):
Total number of Wired computer/s:
Total number of Wireless Computer/s:
Operatins System used on computers:
Feb 15, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Need to install Wireless-G Broadband Router 2.4
try this website...http://74.125.153.132/search?q=cache:N_ltt9u-l0AJ:mac.softpedia.com/get/Drivers/Linksys-Wireless-G-Broadband-Router-WRT54GS.shtml+software+for+linksys+wireless+router&cd=2&hl=en&ct=clnk.....thanks for using fix ya!please dont forget to rate my solution
May 30, 2009 | Linksys Wireless-G Broadband Router
Linksys WRT160N PROBLEM... PLEASE HELP...
Some time what happer router will start blocking the data , in that case what you have to do is that you need to reconfigure the linksys router . First press the reset button for 30 sec , then remove the power for 30 sec and now your router is ready to reconfigure with your setup disk .
if you dont have the setup disk , i am pasting some router reconfiguration steps and i am sure that will help you out .
Please Double Click on the Internet Explorer and on the Address bar,
type in 192.168.1.1 and Press Enter.
Leave the Username blank and type "admin" in the password.
Step 04:
Configure Wireless Settings:
1. Please click on Wireless tab on the router's setup page.
2. Make sure that the Wireless Network Mode is set to Mixed.
3. Change the Wireless Network Name or the SSID from Linksys into your name.
4. For the Wireless Channel, please change it from 6 to 11.
5. Enable the Wireless SSID Broadcast
6. After that, please click on the Save Settings button.
Apply Security Encryption
1. When the router's setup page appears, please click on the "Wireless" tab.
2. When the Wireless area appears, click on the "Wireless Security" sub tab.
3. When the Wireless Security area appears, Change the Mode to WPA personal.
4. Enter the password of your choice in the WPA shared key (it should be minimum 8 characters) and then save the settings.
Step 05:
1. Under Basic Setup tab and set the "Internet Connection Type" to
Automatic-DHCP. After that, please save the settings.
2. Click on the the MAC Address Clone sub tab.
3. In the “MAC Clone” section, set the option to Enable.
4. Click on the Clone Your PC’s MAC button.
5. After that, please save the settings.
Step 06:
Power Cycle:
1. Unplug the router’s power cable.
2. Unplug the Broadband modem’s power cable.
3. Wait for 30 seconds.
4. Plug in the Broadband modem’s power cable and wait for its
lights to stop blinking.
5. Plug in the router's power cable once the modem’s lights stop
blinking.
6. Finally, Test the Internet connection.
Apr 11, 2009 | Linksys WRT160N Wireless Router
Satellite A105: I am trying to instate new Linksys software, cd drive tries to spin the disk for a couple of minutes and then shuts off. If I rt-click on cd drive in "My Computer" then click on "Open" I...
You can configure your router without the setup disk , or you can talk to linksys tech support at 18003267114 - (very good free support ) or you can follow these directions :---
After making the conection
Step 04:
Step 05:
Step 06:
Power Cycle:
blinking.
Mar 20, 2009 | Toshiba Satellite P105-S6104 Notebook
Where can i get a driver for my cardbus corega cg-wlcb11v3?
Find your drivers on this page:
http://www.wireless-driver.com/wifi/corega.htm
Copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 13, 2008 | NetGear WG511 Cardbus PCMCIA 802.11g...
Lexmark 4800 series reset printer to factory wireless settings
i have a lexmark printer its plugged in but dont have a icon to make it print
Oct 07, 2008 | Office Equipment & Supplies
Corega FEther PCC_TXD driver
I need the make and model of your computer or, the type of network card you have.
David
Dec 05, 2007 | Corega (COR-00008-10) Network Adapter
Computers & Internet Logo
David Payne
David Payne
