Question about KitchenAid 32 in. KECC502 Electric Cooktop
ELEMENT WONT SHUT OFF
I HAVE ONE ELEMENT THAT STAYS ON EVEN WHEN THE KNOB IS TURNED OFF, I MUST SHUT OFF THE COOKTOP AT THE FUSEBOX, I HAVE A KITCHENAID GLASS COOKTOP
    President:
  • 1,214 Answers
Sounds like that specific element has shorted to ground inside it's sheath. You'll probably find the element does not get as hot as it normally would.
A fuse will not blow, or breaker not throw, because of the point in the element that the element has grounded.
Elements are available from a number of resources.
A way to test if the element is shorted to ground:
Tools needed -
Ohmeter
1)Disconnect power from the appliance
2) Remove the element (Sometimes they are plugged in, sometimes the wires screw onto the ends of the element.
3) Set the Ohmeter to Rx1000 or more.
4) Measure the resistance between the outside metal sheath, and either of the two power connection points on either end of the element. Under any condition, you should not get a reading. If you do, the element is bad, and you need to get a new one. They are not repairable.
5) Re-install in the reverse removed.
6) Check all connections are clean and all is re-assembled as you originally found it.
7) Turn on power and check if element comes on.
It is unlikely the problem is with the control, but it is a possibility. Give me more info about the cook-top (make, model) so I can investigate further.
Posted on Jan 14, 2009
I have a cookto maytag mgc5430 and the ignition clicking wont shut off i have to unplug stove for it to stop
Hi zwerling,
Moisture or water have come into contact with your ignition devices, they just need to be dried.
Please follow my directions on the Tip below on how to do this:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 07, 2011 | Maytag MGC5430 Gas Cooktop
Electric Oven stays on when even though turned off! Oven is already warm in the morning even though the knob is in off position. Could it be the switch?
HI, this will require the skilled hands of a qualified GE tech. the damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible.
Jun 11, 2009 | Jenn-Air JED8230 Electric Cooktop
Water boiled over into control knobs for the cook top elements.
Just fixed this problem and repaired the corner of the Ceran cooktop.
Disclaimer: These cooktops run on 220V and will kill you if you don't know how to work with electricity. If you're unsure, get some help.
The boiling water slopped out of your pot, and went over to your controls (knobs) and went down the shaft and into a component call "Infinity Switch". The water caused the switch internally to weld one of the two internal sets of contact points into a permanent position. The fix is to replace the
"Infinity Switch" that the boiling water spilled into. The Infinity switch is the component that the control knob slides on to.
In my cooktop one of the infinity switches failed and appears to damage the adjacent switch. Mine actually caught on fire and damaged the wiring and the connector. Hopefully you are better off. Since they were in such close proximity I replaced them both. For $20 you might consider the same. I replaced both to be safe and they were $21.47 each.
My cooktop has 4 elements 2 small, 1 large and 1 combined (small and large) surface. A large element was definitely damaged and possibly a small element. I ordered both. I mention this in case a multi-element was damaged on your cooktop.
You will need to contact either Jenn-Air or someone. Since you can't see an exploded parts list online, you'll have to use the schematic. It is in a plastic sleeve and it stuck to the side of the ventilator housing underneath the cooktop.
When you wire the new part in, make sure you have the wiring correct or when you turn it back on you will burn up the new part.
I hope this helps.
Apr 02, 2009 | Jenn-Air JED8430 Electric Cooktop
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
My Viking VECU105 electric cooktop has one burner which will not regulate the temperature. It can be turned on and off with the control knob, but after that, there is no temperature control. Any ideas on...
It will need either a dual infinite or infinite switch, If the burner has an inner an outer element then it requires the dual.
Firstly turn power off at breaker.
The unit needs to be removed from the cut out and the cover removed from below the swtichs. the knob taken off and the secureing screws removed, then take note of the layout of the wiring and the poistion of the switch, then swap the wires, reassemble test and then re-install
Feb 18, 2009 | Viking 31 in. VECU105 Electric Cooktop
Tripping breaker
Replace the burner and receptacle and you should be short free. You may also need to replace the surface element switch too if it doesn't come on at all or stays on high regardless off knob setting.
Dec 16, 2008 | Jenn-Air JED8430 Electric Cooktop
Element on ceramic Frigidaire Gallery cooktop won't go off.
take knob off and check the middle is not split and hence not turning the shaft
Nov 20, 2008 | Frigidaire Cooktops
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
KitchenAid 32 in. KECC502 Electric Cooktop Logo
278 people viewed this question
Top KitchenAid Cooktops Experts
vince
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
