Question about Westinghouse LTV-20V4 20 in. EDTV-Ready LCD Television
WESTINGTONHOUSE MODEL # LTV20V4 LCD NO PICTURE CONTROLS DONT WORK
WEVE ONLY HAD THIS FOR 2 YEARS AND ALL OF A SUDDEN THE SCREEN WENT BLACK NO PICTURE BUT THE SOUND IS STILL THERE. THE WEIRD THING IS THE CONTROLS DONT WORK ON THE TV NOW AND THEY DID BEFORE ANY SUGGESTIONS IT IS OUT OF WARRABITY AND IT IS FIFTY DOLLARS JUST TO HAVE A REPAIR PERSON LOOK AT IT AND I HAD TO WASTE MONEY IF ITS GOING TO COST MORE THAN BUYING A NEW ONE. THANKS
  • 2 more comments
  • MJT1 Mar 15, 2009
    I have the same problem - screen went blank, but audio is still fine. Unplugged it as described above, but no change. Has anyone found a resolution to this problem?
  • dpetrarca Mar 28, 2009
    EXACTLY THE SAME PROBLEM !!!!!!!!!!!!!
  • adaperry Mar 31, 2009
    The exact same thing happened to me, I woke up this morning and the screen was black. The television still has sound, but no picture!
  • Anonymous Apr 29, 2009
    Tthe screen went blanck, the repair man said that I have to change a integrated circuit but I cant find it any were.
    The part # on the circuit is T 20028 It also has this # V1-000N-27W
    Does any body know were to find this part
  • 3 Answers
I had this problem with these tv`s. The problem actually lies with the power supply inside the unit. Some of the units i`ve seen have 2 blown capacitors on the power supply (C7 and C6) replacing these works. On others, the capacitors as well as a few transistors (Q8 - Q1) are blown. But on all the sets i have seen with this problem, changing the above components restores full functionality to the system.
Posted on Jul 20, 2009
    Scholar:
  • 87 Answers
Unplug this unit from power for about 3 hours and system should reset.
Posted on Jan 14, 2009
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
I bought AVOL TV at the AAFES last black friday Nov.29 nd i have a problem in the TV theres no picture have sound what will I do.weve been watching and suddenly it went out the picture the sounds is still...
If you still have warranty, use it while you have chance. It seems your tv has an issue with lcd pannel. There is a small chance that one of lcd panel cables disconnected from mainboard. If your lcd pannel has an issue (which is the most expensive part between replacement parts of a tv) i suggest you to buy a new tv instead of replacing tv pannel.
Mar 10, 2014 | Sony RMT-V202 Remote Control
My Element 32 inch tv has black screened.
hope I dont sound too crude, but have you checked the contrast and brightness controlls ?? they may be labled as 'picture options' or some other odd label...
does this tv have a LED, LCD or the older CTR display ?? If it is LED or LCD, then the light source that illuminates the screen are not working.. this light source could be damaged..
Sep 09, 2012 | Televison & Video
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
I have a toshiba tv, Model(37xv553d) and bought it in 2009 had no problems with it since ive had it, untill now....I was watching tv as normal and all off sudden the screen went black but still had the...
Now,tv turn on have picture flashes few sec.than dies,have sound left only?Yes the 2 or 1 long boards call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy the 1 or 2 long LCD inverter boards for the replacement.
Aug 19, 2010 | Toshiba Televison & Video
LG Projection Screen No Picture
Hello, if the model number is correct it's not a projection tv, but an LCD tv. If that's correct, it sounds like a bad main board issue part # is AGF31218501...thanks
Apr 25, 2017 | LG 42LC2D 42 in. LCD HDTV
THE SCREEN DONT WORK, IS BLACK, THE SOUND IS OK
Ur LCD inverter board it dead.Must replaced the board.It usally a long board must replaced to get picture back.Tries Shopjimmy.com,Ebay.com to get the board part.
Jan 16, 2010 | Vizio VW32L 32 in. LCD HDTV
I have sound but no picture a all on a Westinghouse LTV20v4. The menu does not come up.
Check for bad capacitors in the inverter board, it may have taken out the 8 transistors when the caps went open.
See the picture here: http://s807.photobucket.com/albums/yy352/budm/WestingHouse_LTV-20V4/
Nov 07, 2009 | Westinghouse LTV-20V4 20 in. EDTV-Ready...
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
I have a Cannon S-400. The screen went blank suddenly while in picture taking mode. When I take a picture of that the picture is also black. Ihave turned it on and off with no change. I have charged the...
it is a CCD FAILURE problem it has nothing to do with LCD if ur pics are black on pc if u check them and lcd shows signs and everything it is 100% CCD issue
but nice part is u can get it repaired FREE OF COST from Canon just see this link and dont forget to rate me FIXYA fot this !!
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
just give them a call and they will send u postage paid envelope no mattter which region u are in it is for the whole world !!!
pls dont forget to rate me
Mar 30, 2009 | Canon Cameras
Westinghouse LTV-20V4 20 in. EDTV-Ready LCD Television Logo
656 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
