Question about Sanyo SR-4310 Compact Refrigerator
Kegorator conversion I'm having to replace my kegorator with a conversion kit on a Sanyo mini fridge. (model# SR4310W). 2 questions, 1. Can I remove the freezer unit? if so, how would you reccomend this be done. 2. I want to poke a hole in the top for a line out to a tower tap, worried about rupturing a freon line by blindly drilling. Are their any spots to avoid drilling?
    President:
  • 1,214 Answers
Refrigerant lines are normally visible on unit's like this. There should be a condenser coil mounted to the outside back of the unit, or underneath the unit, with the compressor. The condenser coil is the one that get's warm or hot when the unit is running.
As for the evaporator, or cooling coil, it is what get's cold when the unit is running, and is normally mounted along the top or back of the unit. As long as you avoid puncturing any of these two coils, you should have no problem drilling holes. However, if this is a conversion kit, there should be instructions for where to drill the holes. If you just bought a refrigerator with the intent of converting, well, you'll need to look the unit over real well using the directions I've given above. The only other thing to look our for is the suction line and liquid lines leading between the inside and outside of the unit. You should be able to find where the enter into the cold box on the inside, and where the exit the cold box on the outside, near the compressor/condenser coil. Manufacturers normally use the shortest route between the two to save material, so you should not have to worry about anything in the top surface. One way to tell is if that surface heats up when the unit is first turned on from not running.
Posted on Jan 14, 2009
How long does a tapped keg of beer last?
This depends on the type of system you are using to tap your keg. A standard tap given to you with a keg will not last very long, just less than a week. If you are using a proper kegorator CO2 system, your beer will last at least two months, if not longer depending on the temperature of your fridge.
Feb 03, 2013 | Wine & Spirits
Puncture hole in my kegorator
Yes, find a licensed refrigeration technician. They will solder the hole and recharge with refrigerant. It should then be as good as new (or however old it is).
Jul 29, 2009 | Haier Refrigerators
Re: Sanyo SR4310W mini fridge freezer plate broken
Ok, I know I should not have done this but I did. I was impatient with the defrosting and stabbed my Sanyo SR3770s' evaporator with my Smith and Wesson switch blade knife. A very tiny hole, made a swooshing noise and now the fridge won't get cold. Can this be repaired for a minimal price? Perhaps just replacing the evaporator plate and reinstalling some freon, maybe, hopefully?
Let me know. Basically a brand new unit, hate to see it go to the dump!
Sandra
Jul 20, 2009 | Sanyo SR-4310 Compact Refrigerator
Temp wont go below 60
Very simple. Call Danby at 1-800-26-DANBY and tell them the issues you are having. The reps there are very knowledgable and more than willing to help. I just had to replace a computer pad and they are awesome to deal with. FYI, the owner's manual does not have a parts listing. Good luck
Mar 31, 2009 | Danby DKC646BLS Full Size / Pony Beer Keg...
Punctured evaporator on sanyo kegorator, how to replace
It might be more economical to get a new refrigerator.
Jun 20, 2008 | Sanyo Refrigerators
Sanyo SR-4310 Compact Refrigerator Logo
334 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
