Question about Frigidaire FMV156EM Microwave Oven
DOOR REPLACEMENT i HAVE RECEIVED A MICRO WAVE DOOR FOR MY FRIGIDAIRE FMV157GC BUT I HAVE NO INSTRUCTION FOR INSTALLATION.PLEASE GUIDE ME.
  • Frigidaire Master
  • 9,098 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 18, 2009
Setting the clock on frigidaire micro wave
You can download Frigidaire owner's manuals and installation instructions here.
Dec 03, 2011 | Microwave Ovens
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
I don't know how to replace the charcoal filter on my Frigidaire FMV157GC microwave. There's also food between the grate and the glass on the microwave door. Help !
This is billed as the Use & Care Manual for the Frigidaire FMV156DC Microwave Oven:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316495004en.pdf
Not sure it is the correct one but you will find instruction for cleaning the exhaust filters on page 19.
Below is the Use & Care Manual for a model direct from the Frigidaire site:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495057en.pdf
This is more helpful as on page 20 it includes illustrated instructions for removing the charcoal filter to change the oven light. Disconnect from power, remove the ventilation grate at the top to access the charcoal filter, slide back and lift to remove. With the grate removed carry out any required cleaning.
Mar 20, 2011 | Frigidaire FMV156DC Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
I have a frigidaire pro series micro wave built in undercounter serial number 7g61910011, I am moving and want to know how I can uninstall..the store personel who installed took the install manual..and I...
Your model number will be on a tag inside the cooking cavity or around the control panel frame or door frame.
You will need that number.
You can download owner's manuals and installation instructions for Electrolux and Frigidaire here.
Nov 25, 2009 | Frigidaire Microwave Ovens
HOW DO WE VENT THE EXHAUST OUT THE TOP OF OUR MICROWAVE when we turn the exhaust fan on it blows out the front but we thought it went out the top so we could vent through a cupboard, attic to the outside
You will have to remove the micro wave from it's mount. Once you have it down, look at the top of the micro wave. There will be a panel that you will have to move from one place (where it is now) to another. This panel will either be on the top of microwave or if the mounting kit has a top plate, it will be on it. The panel normally has two screws holding it in. When you remove it, you will need to re-install it so that it blocks the air flow from coming out of the front. There should already be screw holes where you are to install it. When you have it moved, re-install the micro wave.
I hope I didn't confuse you. The only reason it's not blowing out the top is because whom ever installed it didn't move the panel. All over the stove micro waves come with this movable panel so you can vent it either way you want. If you have the installation papers, it will explain this better. Good luck.
Oct 17, 2009 | Frigidaire Microwave Ovens
Loss of all power when trying to cook/defrost
The cost of repairing the micro wave will out cost the replacement value. If its new then use gaurrantee for replacement
Sep 03, 2009 | Microwave Ovens
I need mounting instructions for frigidaire model plmvz169gcb
Jan 02, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave over the stove
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
It may also be a problem with a door switch or door switch mount.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 27, 2007 | Frigidaire GLMB209D Microwave Oven
Frigidaire FMV156EM Microwave Oven Logo
693 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
