Question about Motorola Mobility RAZR V3c Cellular Phone
Motorla Razr I tried to pair my headset to the Raxr and the screen just go dark on me> I can bearly see the screen. Any suggestions. Thanks
    Novelist:
    Scholar:
  • 111 Answers
HI It is not clear in question. If your screen is dark during pairing mode may be in two cases: 1) The normal case. Your Light Saver in your setup is too short. You need to go to display function and set it to at least 2 mins. Here is where to go: Menu --> Setting --> Initial Setup -->Display timeout--> 2 minutes--> Select 2) The worse case. Your LCD is bad or lcd cable is loosing connection. If this is a case, then you need to open the housing to check for error. Here is the link to show you how to disassembly the v3 housing to fix or replace a LCD or LCD cable: http://www.itsjustmerob.com/razrremoval/RazrV3housinginstall.pdf Good Luck my friend. If you don't know how to replace it, you can check on my fixya.com store and email me your information. I wll reply you with instruction of how to ship your phone to me for repair. Good Luck again and have a nice weekend. Regards, pingping
Posted on Jun 15, 2007
What causes an echo problem with Motorla elite flip paired with a Samsung
You should not have an echo. Can you try pairing with another phone to see if you have the same experience?
You may try resetting the headset ( ELITE FLIP Reset to factory default )
Mark
Motorola Support
May 31, 2014 | Motorola Mobility Elite Flip Bluetooth...
My motorla bluetooth pairs with my cel phone but I can't get any sound. I've tried turning the sound up to the loudest and still nothing. Any suggestions?
Sometimes two diffrent brands will not communicate proper.
Try connect the headset to another phone is it now working?
If Yes --> then I'm sorry but it seems your cel and the headset are not compatible.
If No --> then the problem is most like a technical defect. Go back to your reseller for another headset or let your reseller demonstrate a correct functional headset.
Good Luck.
Aug 03, 2011 | Motorola Mobility Motopure H12 Bluetooth...
How do I pair my Motorla h680 to my blackberry pearl?
In order to pair your headset with your phone, when you turn it on for the first time, its indicator light should be steadily lit in blue, thus indicating it is in pairing mode. If it has been paired to another device before, make sure that that device's bluetooth radio is turned off. If the light is not steadily lit, turn your headset off, wait for some 10 seconds, and turn it on again. Anyway, whilst its light is steadily lit, make you phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (indicator light starts flashing in blue). You see, the pairing procedure between any two bluetooth enabled devices should be performed just once. All subsequent connections between them should be achieved just by bringing they within each other's range, with their bluetooth radios turned on. At most, a simple press on the headset's call button should do.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards,
Carlos
Feb 09, 2011 | Motorola Mobility H680 - Headset -...
Orb headset ps3 will not pair with ps3
have you put the motorla headset in pairing mode?
hold down the middle button for 6 seconds till the light stays solid, then open the boom mic and the light should remain solid indicating the headset is in pairing mode
Sep 28, 2009 | Motorola Mobility H710 Bluetooth Headset
Can't pair with h500 headset with v3
try master resetting and clearing the phone and try pairing again
Aug 28, 2008 | Motorola Mobility RAZR V3
Bluetooth problem
try resetting the phone and pairing the device again and see if that helps.
Mar 12, 2008 | Motorola Mobility RAZR V3
Pairing Jabra BT135 with motorola L2
Your not doing anything wrong it usually means that the headset isn't capable with ur razr or you need to reset both of them and try it again. Hope this helps =)
Feb 25, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Pairing Motorola RAZR with the HS850
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Aug 02, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
