Question about Sony Playstation 3 (PS3) Console
I cant get onto the internet with my playstation 3 .
I have a 40gb playstation 3 and i have 3 usb modem for my internet. I have connected an ethernet cable from my pc to my playstation but it tells me it is unable to find my ip adress or that i dont have my ethenet cable connected. Do i need to get a different internet provider? Why cant i connect?
  • o8alyssa Jan 24, 2009
    my ip addres get founf but then it tells me i need to update my system but when it does it it says it cant find my connection
  • batdog819 Feb 08, 2009
    each time i try to sign on the system tells me unable to find ip address. i just got the internet and the system so i am kinda lost
  • 4 Answers
You can use a crossover cable, but you will have to setup Internet Sharing on your PC and, I assume, manually assign an IP to the PS3. You will also have to keep the PC on all the time. I think the better solution is to get a router or switch and use a straight ethernet cable fron your modem to the router, and another one to the PS3.
Posted on Jan 18, 2009
  • 298 Answers
Use a HUB with that cable, or get a Crossover LAN cable (WalMart or Microcenter $5.99
You cannot connect 2 LAN devices directly to each other with a straight-thru cable. Connection will bounce up/dn/up/dn
You need to use a HUB or switch and 2 straight-thru cables... or get a crossover cable ;-)
  • 3 Answers
If u can get online Playstation Network to the point wer features like adding friends become availible then there shiould be no problem. If you cannot sign in to playstation network then there is a something wrong with your network aettings. If an arror code comes up type into google something like "What does error code *********** on the PS3 mean???". Be specific
Posted on Jan 16, 2009
Sir what purpose usb port and what purpose ethernet port are in zxdsl 831aii modem.
You can connect it to the computer either thorough USB or Ethernet depending on which connection you would like to use Ethernet is a better choice.
Mar 02, 2011 | Computers & Internet
How do i hook up my playstation 3 to the internet using a cable modem
  • Unplug the power cord and the USB cable or Ethernet cable coming from the modem.
  • Wait two minutes and then plug the power cord back in which will reset the modem.
  • Take the straight through Ethernet cable and run it from the LAN port on the back of the PLAYSTATION®3 into the ethernet port on the modem (you may need to unplug the Ethernet cable already in there. Also, make sure a USB cord is not connected to the modem as this will cause your PLAYSTATION®3 not go online).
Turn on the PLAYSTATION®3 to log into the PLAYSTATION®Network (you may need to log in manually if your settings are not set to automatically login). When you are done with your online activity with the PLAYSTATION®3, turn off the PLAYSTATION®3 (refer to the Quick Reference manual) and then follow these directions:
  • Remove the Ethernet cord going from the ethernet port on the modem to the LAN port on the PLAYSTATION®3 out.
  • Reset your modem as you did before my unplugging the power cord for two minutes and then replug the Ethernet cable/USB cord coming from the PC to gain internet access onto your PC. (Please note that this step can be skipped if you do not want to have internet access on your PC at this particular time or do not have a PC at all.)
  • When you would like to log back onto the PLAYSTATION®Network please follow the steps beginning at the top.
The modem setup should appear like this:
From there, please follow these instructions (from SCEA):
  1. Select "Network Settings" under "Settings" in the home menu, and then press the "X" button.
  2. Select "Internet Connection Settings", and then press the "X" button. When a message stating that the Internet connection will be terminated is displayed, select "Yes", and then press the "X" button.
  3. Select "Wired Connection", and then press the "X" button.
  4. Select "Easy" or "Custom" and adjust settings as necessary. Follow the on-screen instructions to adjust the required settings.
Note: You should always choose Easy before going onto to adjusting the Custom settings. In most cases, the Easy settings will work and are set automatically so you won't have to search for information that could have been gathered automatically.
Feb 25, 2011 | Sony Video Game Consoles & Games
The laptop turns on but wont log onto the internet
first you must have an ISP Internet Service provider which will provide you with a modem and leads you can choose either a dial up,usb,or an ethernet connection to connect to the net or if you have a laptop you can choose a wireless usb modem which can work on a desktop aswell once you recieve the modem just insert the disk provided and follow the prompts
hope this helps
Dec 13, 2010 | Computers & Internet
How cann i easily get my ps3 hooooked up to the internet???
here is the most simple way using your computer modem
Yes, you can setup with just a modem for broadband access and still play online with the PLAYSTATION®3. You will not be able to access your PC and PLAYSTATION®3 online at the same time. The following steps need to be taken to play using just a modem:
modemonly.jpgFrom there, please follow these instructions (from SCEA):
  2. Select "Internet Connection Settings", and then press the "X" button. When a message stating that the Internet connection will be terminated is displayed, select “Yes”, and then press the "X" button.
Note: You should always choose Easy before going onto to adjusting the Custom settings. In most cases, the Easy settings will work and are set automatically.
here is also a video in case you are a visual learner
please remember to take the time to leave a good rating and testimonial if my help was appreciated.
Mar 26, 2010 | Sony Playstation 3 (PS3) Console
How do i connect my ps3 to the internet
NO DEAR U CAN USE ON INTERNET CABLE USB!!
Nov 04, 2009 | Video Game Consoles & Games
Trying to connect two computers through a sb5101 modem
you cant connect usb and ethernet on that modem at the same time you have to use a router
Mar 15, 2009 | Arris SURFboard® SB5101 Cable Modem
I cant get online ps3
Get a router and do it wirelessly.
Mar 06, 2009 | Sony Playstation 3 (PS3) Console
Motorola surfboard modem
try connecting it though the usb and installing the usb driver came on a cd with the modem.
Or connect to the ethernet and install its driver from the motherboard cd
Aug 29, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Internet connection
Modem? Are you using dialup?
Feb 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
225 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
