FixYa.com
Tags:
RCA P61960 61 in. Rear Projection Television
61 inch proj. warped concave picture. (by 4 users)
posted by josh2576 on Jun 14, 2007
I have a 61 inch projection RCA television and the picture is warped like it is being projected in the inside of a tin can it is concave and I thought the screen was warped but its not. Any ideas would be greatly appreciated thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by emorse, posted on Jun 01, 2008
how did you fix the problem of your picture warping. i am having the same problem.
Comment by tap41653, posted on May 18, 2008
I have the same model TV and the image on the screen is too wide, and the top and bottom of the screen is skewed. It appears as if the projection inside the TV is off. Any help?
Comment by RudyHS, posted on Dec 27, 2007
My Tv concave from the top and bottom and it turns off and turns back on by itself .Sometimes it will turn off completley. Any solutions?
Best Solution
posted on Jul 01, 2007
FixYa! (100)
techman
Rank:Guru Guru
Rating: 87%, 6692 votes
convergence power supply problem
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 14, 2007
Thanks for Trying (70)
premtech
Rank:Guru Guru
Rating: 89%, 810 votes
Josh
Any chance you could send a photo... Too many ideas come to mind from what you've described. Would actually have to see the "warp" in the picture itself to see if it's one or all colors, any boarders and if the bend is actually pulling from top or bottom..
Bill
premtech@willapabay.org
Can you Help with these Projection Televisions problems?
p61960
picture to big for screen Answer This...
rca p61960 projection tv
it looks like the picture is to... Answer This...
need new screen
broke my screen moving and was... Answer This...
HELP MY TELEVISION HAS NO...
Model number P61690 61in.... Answer This...
the color contast is not right
the lighting is fading, Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
