Question about Kenmore 54701 Dehumidifier
Dead dehumidifier At power up, humidity display says ON and is unresponsive. Restart is no help. There is frost forming on about two tubes worth of the coil. Unit is not pulling water out of the air. Sound like bad brain to you? Worth fixing? daveyk
  • 3 Answers
Pull the bucket out... reach up under the bottom edge of the display bezel and pull down on the back edge to get the filter out; rinse out/off thoroughly, dry and reinstall it...
Get some airflow thru there!
Good Luck!
Posted on Dec 04, 2007
Dehumidifier runs continuously and displays higher than normal humidity levels.
Probably some glitch with the sensors. I recommend taking it to a service center.
Dec 06, 2013 | Haier DE65EK 65 Pints eco-Friendly...
Westinghouse Heavy Duty 25 Dehumidifier frost on coils
MIKE - I have the same problem...previously, there was NEVER any frost, and the unit worked just fine. Now, all of a sudden in the last week, frost has been forming...water no longer traverses thru the tube into the sink...and the unit is basically useless/
I think when the original person said "frost", they meant ICE!
Jul 27, 2013 | Dehumidifiers
New Whirlpool gold dehumidifier last summer. Used since then. It still runs (fan) but no water is being taken from the air. I clean the filters, looked at coils, they are like brand new. I hate to give up,...
Kim, it may simply be a case of the humidity extraction level being set to HIGH. Lower it to 35%. If it's an analog unit (No LED Display) turn the humidity extraction knob to Maximum. More often than not, this will solve the problem. If it doesn't the humidity sensor may need to be replaced.
I hope this helped you and thanks for choosing FixYa.
Aug 17, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
The dehumidifier wont work even the lights was on and it show Lo all the times and we do not know why it happen and how can we get it fixed as we live in Oshawa, Ontario?
I found this on the web
Q - Will my dehumidifier work in a cold room ?
A - A dehumidifier will not operate satisfactory in a room that is below 65 degrees F. At this temperature it will become necessary to operate the dehumidifying coil below freezing temperatures in order to reduce the relative humidity to a reasonable valve. Frost on coils usually will appear.
I would imaging that the humidity is already lower than the dehumidifier could get it down to. that's why it reads "Lo" on the display.
Jan 10, 2011 | Haier 45-Pint Dehumidifier
The coils frost up for Kenmore dehumidifier model 580.53701300 even the temp is > 70. the fan works fine. there is a few water in the water bucket. the humidity> 65%.
check the drain tube for blockage, maybe run a small rubber hose to clear out blockage so condensation can drain freely. Worth a try worked for me
May 03, 2009 | LG LD65EL Dehumidifier
Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Jun 02, 2008 | Goldstar DH5010B Dehumidifier
No 120v to fan motor
It sounds as if this may have electronic controls on it. If so, the problem could be related to too low of an ambient temperature or too low humidity in the air. If this design has a temperature sensor built into it, you may be experiencing "hibernation mode", where the unit will appear to be dead, when it is actually awaiting the proper temperature to employ itself.
The following statement is a parameter for all dehumidifiers and some of the control issues may vary, but the theory is the same.
Dave E. (Illeagle)
Jun 02, 2008 | Kenmore 54351 Dehumidifier
Friedrich dehumidifier
Dave E. (Illeagle)
Jun 01, 2008 | Friedrich D50C Dehumidifier
Kenmore Dehumidifier Won't Power On - No Lights, No Action
Dave E. (Illeagle)
Jun 01, 2008 | Dehumidifiers
Kenmore dehumidifier model 5230
the unit has a sealed system leak and needs pro repair call sears or a&e at 800-905-9505 for service
Apr 28, 2008 | Kenmore 5230 Dehumidifier
Kenmore 54701 Dehumidifier Logo
107 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
