Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
Nails won't set
I have a N88RH that won't set the nails. They are always out @ 3/8" from the surface of the wood
  • cabinets615 Jan 17, 2009
    I have actually found out that the nail gun was suppose to come with two tips. This one did not, so I have ordered the framing tip.
    Scholar:
  • 35 Answers
The Bostitch should have a one-touch depth-mechanism with seven settings. You should make the required adustment(s) to this mechanism to alter the nail depth.
Note: While it is at first glance easy to use, after switching the settings a number of times it may become apparent that the coarse settings lack the refinement necessary for smooth and detailed adjustment.
Posted on Jan 14, 2009
  • Sheldon Scott
    Sheldon Scott Jan 17, 2009
    I believe that I answered this question to the best of my abilities concerning the information that you provided.
My bostitch n88rh framing nailer will fire when pointed down but wont fire pointed horizontal.
Nailers are made to use in any position so must be something simple to fix. Most likely safety contact foot, to test, remove the nails, remove the trigger to expose the firing button on the trigger valve. Connect air and dry fire onto wood or old coiled rubber hose in various positions. If the gun tests ok then carefully examine safety foot mech. and trigger for loose components missing guide or roll pin. The contact foot must push firmly up on the lever within the trigger thus pushing on the firing button. If the safety foot and trigger are in good conditon and working ok, then problem is within the headvalve and piston orings. To test piston oring, remove airline and nails, point nailer up then down again. The piston should stay in the top position. If the piston moves up /down with movement of gun, replace piston oring. If piston oring ok, remove the head and pull out the headvalve. Apply plenty of silicone paste or white grease to orings on headvalve and reinstall and test. If tests ok, then problem is worn orings in the head /headvalve. You can keep lubing or replace orings. Examine the surface within the head where headvalve orings make contact. If there are many fine scratches, even new orings will not work very well. Try to remove scratches with very fine sandpaper. Good luck
Apr 29, 2012 | Stanley Bostitch N88rh Framing Nailer...
My bostitch N88RH is not firing nails
May occur when headvalve or driver is stuck (will usually make a pop or click when tigger is depressed), or tigger valve has failed or safety not actually touching trigger firing pin. Easy test, remove nails, remove trigger by pushing out 3mm roll pin or bolt to expose the firing pin. Pull back nail feeder and place the nose against piece of wood ~ depress trigger with very quick motion with finger. If it fires, reinstall trigger and adjust safety foot so that the firing pin is pushed all the way in. If does not fire, replace trigger valve (usually tva6) or remove trigger valve and replace the 3 orings on the inner plunger. If you hear a pop or click when you do test above, remove head and lube the headvalve orings with white grease or silicone paste.
Nov 17, 2011 | Stanley Bostitch N88rh Framing Nailer...
Nail gun 58-8434-4 will not drive 3" nails all the
Hi foxden503,
Welcome to fixya!
As a general rule, framing nailers use anywhere from 45 to 120 psi to drive nails. But this also depends on the hardness of the wood.
The nail head should be flush with the surface. If it sticks above the wood, increase the pressure a little bit at a time until you achieve this goal.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 20, 2011 | Tools & Hardware - Others
I have a bostitch model #N88RH. It won't drive nails all the way down. How do I adjust it?
Using the web address below for reference, item number 46 is a small slider button on the nose of your gun. Push in on the slider and adjust the safety nose up into the gun for setting the nail deeper into the work. Good luck on your projects
http://www.ereplacementparts.com/bostitch-n88rh-pneumatic-stick-nailer-parts-c-29443_29458_29650.html
Jun 03, 2011 | Stanley Bostitch N88rh Framing Nailer...
I was shooting 3 inch nains and I switched to 2 inch. after 20 or 30 nails it failed to drive a nail. The driver makes an indention in the wood but does not drive the nail. What are the problem...
Check that the driver is returning all the way to top of the cylinder. Driver will not return to top when lower bumper is cracked, driver is bent, or piston oring is too loose/tight or low air pressure to gun. Also check that the two inch nail is the same angle as the three in. Place the nails on the outside of the rails with the heads aligned with the rail. The first nail should align with the path of the driver. If the head of the first nail is angled back away from the path of the driver, will miss fire.
Mar 25, 2011 | Stanley Bostitch N88rh Framing Nailer...
Bostitch n88rh, driver won't retract, does so after disconnecting air, shoots 2-3 nails then same problem, thanks
Have you put oil in the air chuck inlet lately to lubricate? Let me know if this helps or we can investigate further
Jan 20, 2011 | Stanley Bostitch Nail Gun
My N88rh shoots two nails at a time
N88rh uses a full round head plastic collated nails which are spaced apart enough that the driver cannot hit two nails at once. If your are using other nails that fit into your magazine that are closer together you may in fact drive two nails at once. If, however you are using the correct nail and the nailer shoots twice, then you probable have a very sensitive firing valve. You could change the TVA6 valve or change the actual trigger. To overcome this problem of double firing and you do not want to try changing the firing valve, you need to change the trigger to sequential type instead of bump fire type. This trigger is usually white and will only permit one nail to be fired. Check www.toolpartsdirect.com or bostitch.com for parts. Good holiday
Nov 28, 2010 | Stanley Bostitch N88rh Framing Nailer...
Fires 2 nails
Nail feeder pawl is miss alinged or wrong degree of nails being used!
Jul 23, 2010 | Stanley Bostitch N88rh Framing Nailer...
Framing nailer not setting nails
If your compressor pressure is right (im sure it is) there is a plunger located above the point where the nails come out. A moderately size tool store (not home depot) should have a rebuild kit. For me.it was where I bought my nails
Apr 05, 2009 | Porter Cable FR350A Factory Reconditioned...
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
222 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
