Question about Fisher and Paykel GWL11 Top Load Washer
Beeping and odd light sequence
The washer has been stopping during or after the wash cycle. It then begins to beep about 1 time per second. The 3rd and 4th light in the wash cycle and the first light in the rinse cycle are lit. The manual says I should unplug machine for 60 seconds and then start again. If I do this it runs through completely fine, but then the next time does the same thing. I have also just powered off and advanced it to the rinse cycle it works fine at that point as well. I probably should tell you that a few days be fore this problem started my 11 year son tried to help Mom and in the process overloaded the machine with his bedding including the pillow. The pillow was destroyed n the machine. Good heart. Little experience. One of the tub support brackets broke and we repaired it.
  • khagans0001 Oct 09, 2008
    the washer will fill up then souds like it want to start, tries to spin and then the middle wash light middle rinse and last spine light stays on with beeping sound. my washer is still filled with water....
I have the same problem with my 603 washing machine stopping in the middle of a cycle and i would have to go and manually advance the wash. I have just replaced the top curcuit board with a new one. can you please help or offer a solution. Thank you.
Posted on Oct 05, 2008
SOURCE:
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
I have a Whirlpool washer WFW9050XW00 that stops during the wash cycle. The machine beeps and the wash light flashes 9 times pauses and flashes 1 more time. Thanks in advance
My Washer stopped while washing and will not spin drain or aggitate.
It will power on and off I can change the settings but nothing happens.
Oct 26, 2013 | Washing Machines
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Whirlpool calypso clothes washer stuck on the "FL" for overfill code - will not reset after hitting stop/cancel or after unpluging - one year ago the customer service for whirlpool gave us the...
Try pressing the following key pad buttons within 5 seconds - PREWASH OPTIONS - WASH TIME, PREWASH OPTIONS - WASH TIME, in this sequence and allow the washer to run. The LED display will start counting down as the washer begins a sequence of short diagnostics tests. If no error is present, the washer will return to standby. If the error persists, you may have a blockage in your drain pump. Please run the test and let me know the results. Total test time is about 1 minute 40 seconds. I hope this helps you.
Jul 24, 2008 | Whirlpool Washing Machines
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
The washer has been stopping during or after the wash cycle. It then begins to beep about 1 time per second. The 3rd and 4th light in the wash cycle and the first light in the rinse cycle are lit. The...
Plug off the wall. Open up behind the machine. Check to see if any wires loose. See that the wires from the control panel to the motor are plugged in tight. Vibration from the machine could loosen the wires and give the display wrong readings, or disrupt the run.
Rate me please..........
Dec 26, 2007 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
399 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
