Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Set turns of and on after an hour or so
After the set has been on for an hour or so in shuts down and goes
through a start up. Could this be a lamp or the power supply?
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    what is the exact model number of TV to check its technical info.
  • 90 Answers
Yes..This is most likely the LAMP, But it could also be a thermal sensor. You should first try a new lamp (which you will have to get at some point anyway) and if that does not fix it I would call a professional.
Posted on Jan 14, 2009
I have a Infocus in1503. It shuts down after 10 to 30 minutes. When it does shut down there is no lights. In fact the power light goes off as well.
I seemed to have had the exact same problem... I had placed the projector on top of a small book (to raise the unit), however, did not rest the feet of the projection unit on the book and it overheated and turned off, as a result. (The bottom of the unit was making direct contact with the book which caused it to overheat since not any air was passing through between the two)
After letting it cool for a while and powering it up -- it would usually power off completely for about 15 minutes. After a little thinking, I thought it may be the lamp/bulb and waited a couple of years and bought one online that arrived yesterday.
I installed the new lamp/bulb this morning and it did the same thing. It powered down about a half hour later. Bummer.
I reset the machine to factory defaults and checked to see if it had the 1.03 firmware... It did
Then went through the settings in the setup area and turned off the 'prevent pic screen saver'... Reset the 'lamp hours'
I doubled checked the lamp/bulb installation... Turned it back on -- same thing -- it shut off after about 15 minutes or so... Then unplugged the unit and turned it over and took out the 4 or 5 chassis screws and loosened and took off the side panels and blew onto the fans and circuit board areas and gently pounded the sides to shake anything that shouldn't be there loose and put it back together.
i powered it back on and now it's been working for about 2 hours and 16 minutes!
good luck!
Nov 12, 2013 | InFocus IN1503 DLP Projector
Optoma MovieTime: The Lamp that Won't stay on
its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
Aug 22, 2007 | Optoma MovieTime DV10 Multimedia Projector
Its a DLP that uses a lamp, lamp is possible but I would also look to see if fans are on and running, a fan stopping or even slowing down can trigger the set off also.
Average lamp life is 2000 hours or two years and set if lamp a bit dim may shut set off.
Dec 18, 2012 | Akai PT5598HD 55" Rear Projection...
I have a sony kds 55A2000 and my lamp went out so i replaced it. and it startes up fan goes on and off . and tv shuts down light still blinks red? My optical block is getting a light green yellow tint but...
Lamp Fan should not cut off and on it should run at all times when TV is Turned on.Lamp Fan is designed to run when set is turned on to Keep Lamp Cool otherwise Lamp will burn up.
Yes Bad optical unit block could also cause set to shut down.But most of them will Play but with Dots,Green yellow tinit or Big blue Spots
Jun 23, 2011 | Sony KDS55A2000 55" HDTV
TV goes off after 20 seconds Samsung HLS5086wx
First Take off the Lamp Door and replace it back the way it was secured with all of the screws. Doing this will reset the safety interlock switch which heats up and opens the circuit causing the set to shut down. After doing this and the set still shuts down check the lamp. Depending on the amount of hours on the lamp it may be a bad lamp. They will fail with out any obvious signs. If the set shut down and goes straight to the Stand By condition then you have a bad Power Supply. If you hear a whining or buzzing sound then you have a bad Color Wheel.
Apr 11, 2010 | Samsung HL-S5086W 50" HDTV
I've recently replaced the bulb, thinking it would solve it from turning off (powering down) every so often. Replacing the bulb slow the problem down, but as of late, the problem has worsened. I've also...
Ballast board it is what powers Lamp on and CK the Lamp Fan if it stops and is not keeping Lamp cool then set will shut off.Fans are not to stop running while set is turned ON. Encompass Parts Distrubtion
1-800-638-3328 they might have it in stock.
Feb 16, 2010 | Samsung HLN617W 61" Rear Projection HDTV
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
Tv will go black sound will last a few seconds. It resets and starts for a minute or so. other times it will run for hours with no issue. Some times it restes more just on start up and after it warms up...
If the set shuts down and cycles 3 times before the set goes to the 3 flashing lights on front, I would suspect the lamp causing this issue. Each time the set restarts on its own it boosts the voltage to fire the lamp and after 3 times it's basically 3 strikes and you're out. If you haven't replaced the lamp in a long time then suspect that first.
Nov 11, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Shuts lamp dwons as if over heated. Lamp 4200 hours.
You need to reset the lamp hours. Here is the manual to tell you how to reset.
Good Luck and please Rate. FixYa!
Mar 12, 2009 | Panasonic PT-AE700U Multimedia Projector
Televison shuts makes a sound and shuts off repeatedly
Probably needs an original SONY lamp instead of the "replacement" lamp you put in.
Dec 23, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
