Question about Brother MFC 9700 All-In-One Laser Printer
Need to clean off the rollers
I ran an Avery 3279 (Dark T-shirt Transfer) sheet through the printer and it melted onto the rollers. How do I get the rollers out to clean them off?
  • 1 more comment
  • drsellers Jan 14, 2009
    But first I need to get to it to get it out with out damaging the unit.
  • drsellers Jan 16, 2009
    I tried running thick paper through it and seemed to be getting somewhere but now it says there is an Machine Error 79.
  • drsellers Jan 17, 2009
    Can't get to the rollers! How do you do that?
    Genius:
  • 2,035 Answers
If your getting ME 79 then its mechanical problem ,or hard ware failure in the printer remove the cartridges check the for any obstruction in the path where the paper feeds and also if the rollers work ,if not then it must serviced ..
Good luck....
Posted on Jan 18, 2009
  • 818 Answers
Isopropyl alcohol can be used see also there is two small gears in the rear of the fuser that drive the fuser exit roller.
    Genius:
  • 1,913 Answers
Remove ctrtidge .open the back panel.then unlock all scriw and lock.then pull fuser assembly.then open the rolller then clean with isopropile.
Posted on Jan 17, 2009
  • 2,794 Answers
You can try some alcohol with water in it to try to get it off the roller. You will have to remove the fuser assemly out of the copier and clean the rollers. Make sure it is completely cooled down. I don't know if the the fuser cover has screws on it to remove it to get to the rollers. It it doesn't you will have to get a new fuser roller assmebly. T-shirt transfers require heat and they will lift off of the fuser rollers. You might want to look into using ink jet based transfers in the future.
Posted on Jan 16, 2009
  • Tim Babcock
    Tim Babcock Jan 17, 2009
    That might be a fuser error code you are getting. Your going to save yourself a lot of trouble by simply replacing the fuser assembly.
  • Tim Babcock
    Tim Babcock Jan 18, 2009
    Here is the info on the fuser:
    http://www.precisionroller.com/find/lj71...
    It is an assembly. So if something is bad with it, that whole thing needs to be replaced. You could try getting in there to clean them out isopropyl alcohol and a qtip.
    See where the paper comes out to get to it. Usually you have to disassemble a few covers to get it (depending on the model).
  • Brother Master
  • 19,396 Answers
If the Avery had melted inside you need to take off the drum unit, and gain access to part of the assembly underneath.
Depending on where the paper has melt, you may need to remove the external casing and partially disassemble the unit.
See also: Clean your laser printer safely
Posted on Jan 15, 2009
    Sergeant:
  • 221 Answers
Check out on the back side there is a assess door just remove that door by pulling the locks.and try to remove the sticker from the roller.other wise just pass a little thick sheet of paper from the printer 10 to 15 times iot will get little bit loose or get torned off so you can try to pull that paper into small pieces s;lowly.if nothing possible dont take risk machine is good.a tech at your place is required.thanks.
Posted on Jan 14, 2009
    Sergeant:
    Novelist:
  • 326 Answers
You can apply a greese material on the rollers and rub it with your hands on the rollers manually then apply isoprophyll to clean that greese material from the rollers.or other wise taking it to the repair center for internal cleaning as its not all easy to open the printer withour proper tools.
    President:
  • 2,110 Answers
    Top Expert:
  • Brother Master
  • 79,189 Answers
Try lacquer thinner, but just dampen a rag, don't soak it, take your time. this thinner is avail at any hardware store.
  • 1 more comment
  • yadayada
    yadayada Jan 14, 2009
    U may also want to try GOOF OFF brand cleaner, it may work and is non toxic.
  • yadayada
    go to the Brother site and click on the support tab, u may be able to find the info on how o remove the roller drum.
  • yadayada
    yadayada Jan 16, 2009
    why don't u just replace the roller?
How can I get my Avery 8876 business card sheets to feed through my printer?
Avery is a fairly good name in the business.Brother on the other hand seems to have ignored the reasons why folks don't buy brothers. It's these little annoying things that bigger company's have spent time and energy on. For one there's usually a lever you push to control how much pressure the two fusing rollers push; hot rollers, for years this perplexed the big guys because there all ready is a pretty small tolerance of melting the toner and not burning the paper; melting the toner(powered plastic) next was the ever annoying OHP overhead projector sheets. this is plastic toner on plastic"paper" nightmare! melt the toner but not the plastic its on.... Well enough of engineering issues, time and perseverance paid off. now comes a sticky label on a waxxy surface that is twice as thick as paper and yet has toner to be fixed on it and dried....Some company's like cannon tried a cold roller that seemed to work at first but when things went bad they really went bad.labels coming off all in the wrong places... Toshiba and Savin Ricoh decided to get with Avery and others and make one side harder to come off than the other; reduce the squeeze pressure and increase the opposite "static cling" voltage. Also the angle it hit the feed section// Bypass feed only/Lt-R. Following the printed directions in the individual label sheet seemed to reduce the issue to a minimum. Understanding all the changes the poor piece has to go go through in an 8second processes is half the battle. hope this helps a smidge~~~SC
Nov 08, 2014 | Office Equipment & Supplies
Is Canon PIXMA IP1800 can handle T-Shirt Transfer Paper? if it can, what kind of transfer paper that will be good for IP1800?
There are several brands of T-Shirt transfer paper out there, and all are designed to work with InkJet printers just like yours. Personally I've used the Avery brand sheets, and they are widely available at local stores like WalMart, Staples, OfficeMax, etc.
I've also provided a link to the sheets available for online purchase from Amazon.com -
http://www.amazon.com/Avery-Personal-Creations-T-Shirt-Transfer/dp/B004E2S3MC
May 05, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My wife tried to print on T-Shirt tranfers meant for ink-jet printers, and they melted onto the fuser roll, and it stinks. I need to remove the fuser assembly and clean it, but could use some instructions....
This might help. I did the same thing with my laserjet printer.
Staples has laserjet cleaning sheets. I ran several sheets through the printer after I pulled most of the transfer paper out.
The sheets are one use sheets so, you will need a few.They are impregnated with cleaning fluid on textured paper.
These sheets clean the entire paper travel path.
Dec 12, 2009 | Brother MFC-7820N Laser Printer
Label misalignment for 14 label per sheet
Open the rear door and clean all rubber rollers with alcohol
Jun 27, 2009 | HP Officejet 4315 All-in-One Printer
Canon PC850
1.replace OPC drum
2.clean your Canon...
Jan 20, 2009 | Office Equipment & Supplies
Printing dark tshirt transfers - can't override the flipped image
Hello I think I can help you. I Would not use T shirt transfer when you make up your print I would select poster print or any other form that does not automatically reverse the image. The reason your software is designed to do this is on the regular transfer paper your laying the image down on the shirt, so for it to come out right it has to be reversed. With the dark T shirt transfer paper your peeling off the backing and putting the image face up on the T Shirt.
Dec 23, 2008 | Canon i80 InkJet Printer
HP LaserJet 1012 Printer prints ghost images
I ran the hp toolbox "cleaning" mode too and it did not help the problem at all. I still have a dark smear concentrated in the middle of the page, and ghost images repeated lighter all the way down the page.
Aug 21, 2008 | HP LaserJet 1012 Printer
I am using Avery T-shirt transfer paper. The man in the white uniform keeps printing green instead of white. I am putting this photot on a white t-shirt, printed from my HP Photo Smart D7360. After...
GREEN is a combination of Cyan and Yellow, although i would assume that all other colors are working fine if you can find a printing properties, and reduce the amount of cyan it would help you a bit until you have achieved your desired result.
otherwise you may have to recalibrate your printer to suit a perfect color matching
Aug 11, 2008 | Avery Office Equipment & Supplies
Printing business cards
Feed sheets through front manuel feed slot.
base tray is mainly for up to 90grm paper,anything heavier
can feed for a time but tends to fault.also try and clean the
paper pick up rollers regularly.
mongrelken.
May 20, 2008 | Brother HL-2040 Laser Printer
Brother MFC 9700 All-In-One Laser Printer Logo
79 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
