Question about ASUS K8N-VM Motherboard
Motherboard live then 1 beep followed by 4 beeps then nothing.
Home built computer with K8N-VM motherboard. 1 gb Ram. 1 20GB harddrive. No OS yet. Everything looks OK. All wired up. Just stumped. I'm a silver surfer building 1st build computer
    Sergeant:
  • 367 Answers
The one beep is usually normal for most computers. Is your Video card seated correctly?
4 beeps Refresh error RAM is not refreshing correctly. Reset the refresh values in the BIOS or reset the BIOS.
Posted on Jan 14, 2009
How much memory can the k8n neo2 msi coolmaster motherboard take
The k8n supports a max of 4GB Ram but to be able to access all of the 4gb you need to have a 64 Bit OS or you can only access 3.26 GB.
Mar 02, 2011 | Computers & Internet
MSI K8N Neo V2.0 beep code problem is continous beeps.
That's usually a bad ram stick. Shut down the pc & remove one stick at a time starting with the one furthest from the cpu & work your way down to the first one. When it boots without the constant "beep", you found the bad one! You can also check www.msi.com & look in the support area for a solution if mine is wrong.(I'm never wrong though,lol)
May 16, 2010 | MSI K8N Neo Platinum, 601-7030-010,...
K8n-dl mb does not post. only action that comes is beep/beep off/beep/and on and on. This is with only one processor in and no ram. put pciexpress video card in and screen is blank. put second processor in...
The beep beep code is an audible code telling you that you have no Ram installed. You cannot run this board without system ram. Fit some system ram and connect a video card and a drive. Make sure both cpu's are fitted and try again. If it still beeps, note the length and number of beeps and go to the ASUS website. You can find the audible codes in the support section under bios fault codes..
Dec 23, 2009 | ASUS K8N-DL Motherboard
Asus p4p800-vm 2 beeps then 6 beeps
This is RAM problem, your RAM is not working well. please replace RAMs then check it will work fine..
Please dont forget to rank my answer
Sep 05, 2009 | ASUS P4P800-VM Motherboard
3 beep at the start
Thats a standard mother board warning...back when i built a few computers i got this all the time it meant "no Memory" or no ram chips were installed or that the memory was not compatible it should just beep three times with about a second delay in between each beep...then thats your problem...your ram might be dead! if it has 3 short beeps and boots up fine it could just be a start up beep i know of older computers beeping quickly 3 times before booting....though ive never delt with asus boards only Intel. but i doubt it would be much different
hope this helps,ben
Aug 13, 2009 | ASUS P5S800-VM Motherboard
Problem with Asus P5RD2-VM
i think you system also show the beep.
when this problem occured.
your ram may not be compatible for your system.
to solve the problem use this help
1-change the RAM
2-Ram insert into another Slots
3-may be 1 gb RAM not support to your system.
Apr 11, 2009 | ASUS P5RD2-VM Motherboard
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
K8n-lr motherboard
1 long beep and 2 shorts beeps indicates a problem with your RAM. If you have more than one RAM chip, remove one of them to rule out a faulty chip. If you only have one chip, remove and reseat it. For clarity, you can find the manual for your board at; http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8N-LR And the Asus general motherboard troubleshooting manual at; http://support.asus.com/images/document/ts/E2437_MB.zip
May 30, 2008 | ASUS K8N-LR Motherboard
Pc do not boot
first check the specs according to the manual of your ram memory. is this complies rom the manual? did you installed video card? if you installed video card then temporarily remove this and use the on board. if still doesn't boot the ram memory is the problem. there are diferent kinds of beep sound according to hardware problem we have the long beep, a continous beep and so on.
Nov 03, 2007 | ASUS K8N-E Deluxe nVidia nForce3 250...
ASUS K8N-VM Motherboard Logo
127 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
