Question about HP Officejet 5610 All-In-One InkJet Printer
The paper trays were removed for transportation. I am trying to fit the proper paper trays back into their proper locations. Unable to find a picture showing how to install the paper trays.
    Genius:
  • 1,605 Answers
Since this set will allow me to attach a large JPG and writing.
i have to send you the HP website. it show you how the paper tray shoudl be installed.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00442099&lc=en&dlc=en&cc=us&product=441125&lang=en
Posted on Jan 14, 2009
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
Mfc240 c gives unable to print see troubleshooting guide 51 I have tried all I know to do
The message Paper Jam may appear on the display if the Brother machine is not feeding paper correctly, paper scraps have become stuck in the print head path, the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
To solve this problem, please follow the steps listed below:
Note : images shown below are from the representative product and may differ from your Brother machine.
  1. Disconnect the machine from the power supply.
  2. Turn the unit around and remove the Jam Clear Cover from the back of the machine by grasping it at the Center and pulling it straight away from the rear of the machine.
    Caution DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
  3. Look for any paper scraps, jammed paper or foreign objects in the rear of the unit. If anything is found, remove it.
    Be careful not to touch the feed roller.
  4. Remove the Paper Tray from the machine.
  5. Remove any remaining or jammed paper from the front of the machine.
  6. Look inside the machine, where the paper tray was installed and locate the white PE Actuator.
Caution Do not stand the machine on end. Ink may leak from the machine.
The PE Actuator looks like a 2 prong fork or tuning fork and is located near the rear center of the machine where the paper tray slides in. It is located between the 2 gray rollers.
  • If the White PE Actuator is in place, continue to Step 7.
  • If the White PE Actuator is missing, please contact Brother Customer Service from "Contact Us".
Using both hands, use the plastic tabs on both sides of machine to lift the flat-bed scanner until it locks securely into the open position.
  • Carefully examine areas 1 and 2 at the left and right hand ends of the platen area for paper scraps.
  • These scraps may have become saturated with ink and be difficult to see.
  • Use a flashlight if necessary to check thoroughly.
Aug 13, 2011 | Brother Office Equipment & Supplies
Sharp AR-205 misfeeds at transport area from both paper trays and bypass tray both. Tested using different paper in all trays and still won't feed in at the transport area. The paper just pleats up...
it means the drum is not moving check it, insert it properly. or therre is a broken gear somewhere or the motor that makes the drum to rotate is not working properly. The registration sensor not working or not postioned properly.
Aug 01, 2011 | Sharp Office Equipment & Supplies
Our mfc5460 brother printer is giving the error message "print unable 30" and "print unable 50" alternately. WE had a paper jam, removed everything we could see from top and back, and are now stuck. We...
  • Remove the input paper tray and take off the output tray. Remove all loose paper from the input tray.
  • Step 2Pull out the paper support flap and unfold it to its greatest length.
  • Step 3Flip through the stack of paper before inserting it back into the input tray. Place the paper in the tray and adjust the paper guides so they press against the margins of the paper.
  • Step 4Ensure that the stack of paper is below the maximum paper line on the inside of the input tray. Unplug the power cord from the back of the printer.
  • Aug 09, 2010 | Brother MFC-5460CN All-In-One InkJet...
    Hello, I have a Dell 3130cn printer. IT is currently displaying the following message: Paper Jam 071-100 / Open Tray 1 and remove paper / Open and close the Front panel. I have done all of these things. I...
    This error can also be caused by other problems, two of which are as follows.
    1) The paper tray has a flap which opens when the MPF (Multi Purpose Feeder) is lowered. If this flap has been pushed out of one of its pivot points due to 'rough' handling of the paper tray, it can cause paper jams, and it can sometime cause the printer to 'think' it has a jam.
    Just re-locate the flap properly, and make sure that it does open when you pull the MPF down.
    I've seen this happen on a fe of these printers - keep your thumb OFF the flap of the paper tray when you open and close it to reload it with paper.
    2) Paper quality can be a cause - seen this happen on this printer when a different paper was used - more likely with a printer that has done a lot of work and the pickup/transport rollers are starting to wear.
    Replacement pickup and transport rollers are available quite cheaply on THAT well known internet auction site (and probably elsewhere to)
    Apr 19, 2010 | Dell 3130cn Color Laser Printer
    JAM E, UNNABLE TO CLEAR ERROR
    Jam E normally cause by the paper path sensor came off during when you clear a paper jam.. the sensor is located at middle side , to fix it back you will need to remove the E cover..and remove the transport unit...4 screws.. but putting it back will need to have some technical know how as fitting it back wrongly will cause you unit not able to feed paper due to the plastic blocking the paper path.
    Will upload some instruction later...
    Apr 14, 2010 | Epson Aculaser C1100 Printer
    I have a HP Photosmart 3210 printer with a paper jam. I am unable to remove the paper tray so I can pull the jammed paper out. Can you tell me how to remove the tray?
    Don't try to remove the tray. Most jams can be rectified from the back access panel.
    HP has a video tutorial on the subject: (copy and paste this link into location bar of your browser)
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00410130&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=439488&lang=en
    Dec 05, 2009 | Computers & Internet
    Clear paper jam message but no paper jam
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check if the Encoder Strip is Broken or Missing
    1.Power down the printer and unplug the power.
    2.Slide the cartridge carrier inside the printer a couple of inches to the left.
    3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
    Note:
    The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
    Reposition the Encoder Strip
    1. Remove the power cord from the printer.
    2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
    3. Gently slide the ink cartridge carrier to the middle of the printer.
    4. Gently move the top part of the printer belt to the right.
    5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
    6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
    7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
    8. Once the encoder strip has been re-seated, close the scanner lid.
    9. Re-connect the power cord to the printer.
    Ensure the Paper Tray is Not Overfilled
    Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
    Adjust the Printer Paper Guides
    Adjust the paper guides to fit the size paper being used .The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides.
    Locate and Remove Any Obstructions Inside the Printer and Input Tray
    1. Open the front cover and make sure the kickstand (if there is one) is engaged.
    2. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects.
    3. Close the cover.
    4. Remove all paper from the input tray.
    5. Inspect the input tray for any obstructions.\
    6. Remove any visible obstructions.
    7. Reinsert the paper.
    Clean the paper feed roller on the printer.
    1. Power down the printer and disconnect the power cord.
    2. Remove all paper from the input tray.
    3. Wipe the roller gently with a damp cloth.
    Aug 13, 2008 | Dell 924 All-in-One InkJet Printer
    Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
    Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
    Nov 29, 2007 | Office Equipment & Supplies
    Printing problem
    Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
    Note:
    3. Close the cover.
    Nov 22, 2007 | Dell 922 All-In-One InkJet Printer
    HP Officejet 5610 All-In-One InkJet Printer Logo
    116 people viewed this question
    Ben Johnson
