Question about Acer AL2216W LCD Monitor
Acer Monitor and Mac OS X issues?
I am running Mac OS x (10.3.9) on my Power PC G5 (dual 2.5ghz). Had no monitor issues, but with my new Acer AL2216W monitor, the monitor flickers (visually vibrates) then blacks out for a few seconds intermittently, gradually getting worse. I have tried to find a MAC driver to download, but ACER only offers drivers for Windows systems. so... is it the driver? is it the monitor?
thanks in advance.
SOURCE: Acer AL1916W monitor
ive set that resolution but its still flickering on 60hz :S
i dont know what else to do. Ive installed new drivers for my graphics, ati radeon 9550..i dont know what else to do..PLS HELP ME!!!!
Thanx
Posted on Dec 14, 2007
  • 198 Answers
SOURCE: unable to install AL1916w lcd driver in xp
i buyed the new al1916w lcd monitor ,i tried to install the driver for it.
i also downloaded the driver from acer site ,when i looked in device manager ,i found two plug and play monitor
plz check this link
<a href="http://imageshack.us"><img src="http://img151.imageshack.us/img151/2717/48550554nr5.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
then i selected update driver from the right click and selected the folder wherethe driver was stored ,after searching windows cannot find the drivers.
i am sure that the folder has the driver downloaded from the site.
check this link
<a href="http://imageshack.us"><img src="http://img100.imageshack.us/img100/71/28697132zh8.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a><br/>
now how can i install the lcd monitor driver?
any other method?
Posted on Feb 20, 2008
JULIANFIX
  • 975 Answers
SOURCE: AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
Posted on May 06, 2008
Fix-4U
  • 293 Answers
SOURCE: Text ghosting on Acer 22" widescreen monitor
Hi...there,
It's seems you need to reset your WB (white blance). Open your on screen display and look for WB settings... Good lucks!
Posted on Oct 07, 2008
SOURCE: Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Posted on Dec 30, 2008
I have an Acer Monitor AL2216W and it will come on, the Acer name appears, then no signal and then the green light goes to orange. Is this the power supply or what?
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Here is the inside of your monitor:
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
Dec 22, 2011 | Acer AL2216W LCD Monitor
Acer AL2216W 22" LCD monitor. DVI input apparently
Not Good..
After you've checked that the video cable is connected properly, make sure that all the pins in the video cable plugs are straight and not broken off. Then test on another PC. Make sure your CMOS battery has not gone flat, as some PC's will fail to load basic drivers if CMOS memory is lost. The battery should show no less than 2.5v, if it's marked 3 volts when tested on a multimeter. If you can't test it, just buy a new one at the supermarket or hardware, usually around $4.00.
Next thing to try is your Video Card . If it is an on board one like most are now, there isn't anything you can do but try another card in an expansion slot or fit a new motherboard. At this point, I'm sad to say, you're better taking it to a PC shop where they will have a few things at their disposal to try.
Jan 30, 2011 | Acer AL2216W LCD Monitor
My Acer AL2216W Black LCD Monitor all of a sudden is wavy & flickering!?!?!? Is there anything I can do about it?
Hello,i think your LCD monitor is faulty and you should consider replacement.but first take to a qualified service personnel.
Dec 22, 2010 | Acer AL2216W LCD Monitor
I have same problem
Replace the following capacitors:
3 pcs - 220 microF - 25v
2 pcs - 1000 microF - 25v
1 pc - 2200 microF - 25v
Resolder the 2 transformer legs for the inverter.
Roan
Triangle Tech Whiz.
Jul 23, 2009 | Acer AL2216W LCD Monitor
Ghosting of the image
no it is a board replacement at best, so i would look into replacing the vga board or getting a new monitor and selling the damaged one for parts with the issue listed
May 11, 2008 | Acer AL2216W LCD Monitor
May 06, 2008 | Acer AL2216W LCD Monitor
Horizontal banding that looks like Interference
i would take this in for a service check could be issues that need resolving from a service standpoint not a simple driver or resolution fix
Dec 18, 2007 | Acer AL2216W LCD Monitor
Acer AL2216W LCD Monitor Logo
746 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
